Question about Kenmore Intuition Upright Vacuum
How do you replace brush roller on kenmore intuition vac
How can I open the brush roller compartment in order to clean/replace it?
Tip
Your vacuum cleaner doesn't suck much?
You have emptied the dust canister for many times. You hear the motor running, but it doesn't pick up much. Your vacuum cleaner is still OK...
If the motor was not running at the beginning, I suggest you read some other Fixya troubleshooting tip.
Now it's just TIME to replace these filters.
They come in set of 2, a first one has a cylinder shape and a second one is flat.
I recommend as a good consumer, you to first order a new set, cause this cleaning process may be spread over few days. Unless you wish not vacuum for a while...
After replacing with the new one under the cannister, here is how you RECYCLE the old one.
Important Safety Rules First:
  1. This procedure should be done only outside of your home. Stay away from all clean surfaces as hanging bed sheets, rugs, clothing, and open windows : cause one wind drought may give you more work to do ;-( !
  2. Always wear a safety mask, for obvious reasons: since we don't know what's in there: breathing any dust is very hazardous to your health. Better be safe than... sorry :-(
  3. You should wear rubber gloves and old clothes. Why would you get your hands or your clothes dirty?
Brush out all you can off the cylinder and the flat filter with a cleanup brush or disposable rag.
Soak the used vacuum filters in a disposable container (yogurt or ice cream) ;-) filled with soapy water (1tb spoon dishsoap in 1/2 quart or liter of water). Soak for 10min. Rince once. Refill again with soapy water and let it soak overnight.
Rince it now with clear wather. Looking through it you shall see most of the dust should be gone.
Do not replace these wet filters the same day in your vacuum cleaner because it would obviously damage it's motor. Why do you have to hurry for?
Let it DRY in a warm place or in direct sun for another day! Store it until you are ready to replace it again.
Your have RECYCLED once more! You may do it as a few more times as long as it doesn't affect the performance of your vacuum cleaner.
This process could be applied to many more vacuum cleaners and some household items we normally throw away.
GB
on Dec 16, 2015 | Shark Vacuum Cleaner HEPA Filter X9602H...
Why does my Kenmore intuition vacuum 31810 Red light stay on ?
Here's a couple options
http://www.ehow.com/way_5513470_kenmore-vacuum-troubleshooting.html
http://www.shopyourway.com/questions/1128413
Jul 28, 2014 | Kenmore Intuition 31810 Upright Bagged...
How do i clean the roller
Look to see if the belt broke or belt slip off most of the time is something wrong with the belt. If you change the belt of fix the belt that is the time you clean the brush.
Jul 16, 2014 | Panasonic MC-UL815 MC-UL815
Clean bristles on roller
Remove bristle roller and clean with warm soapy water
Jun 22, 2014 | Kenmore Intuition 31810 Upright Bagged...
How do I clean cat hair out of spin brissels
Hey there! The brushes can be removed for cleaning. With the handle in the upright position, tilt the cleaner back so that handle rests on floor. Grab brush assembly and pull firmly. Remove hair and debris from brushes. You may clean the brushes under running water. If for some reason you are not able to clean the brushes, replacement brushes can be ordered by following the link below.
Search Results
Jun 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
How to open the casing - kenmore intuition 116.312
Similar to your Kenmore upright is the canister. Here is a video clip by another with similar issue of trying to open the darn thing up. I hope this gets you closer to solving your problem with the vacuum. If not with a few Kenmore vacuum "search" in youtube I think you will find what you need.
PEACE
https://www.youtube.com/watch?v=s0aaoPzCAcM Kenmore 116 26212690 vacuum cleaner disassembly to motor
Jun 03, 2014 | Kenmore Intuition 31810 Upright Bagged...
Brush wheel not spinning
it can be belt or clutch failed. put the vac on its side and on the bottom there will be either two push clips or 2 screws remove them or push them and pull the bottom off. then when this is off you will see were the belt is for the spinning brush. if the belt is still on then the clutch has gone in the motor if the belt has gone take out the broken part and get a new belt, fitting new belt you need to remove the spinning brush it is either clipped in or slotted in , clipped is push the clips out to the side and lift the brush out, slotted it will just pull out. clean out the brush before putting back in also check the brushes bearing to make sure it moves easy as a failed bearing do to carpet string etc can burn the belt, any belt that has been burnt in this way should be removed and changed as it will damage the hover if still used after this part has been cleaned replace all parts and then turn on dont and it pluged in mains while you are doing this and dont use until it has all been fitted back..
Mar 26, 2014 | Kenmore Intuition Upright Bagged Vacuum...
The belt won't stay on! I put it onto the silver piece that spins...as soon as I turn it on to test it it comes off...the brush doesn't spin...Am I missing a part??
Cathy
The brush roller only sits one way and must b free rotating not jammed up if roller is tight to turn disassemble and clean it when u put it back after u have put belt on turn by hand to see if it stays on, if it does ok done .
Cathy theirs ,
only to things that will cause this the brush roller running out of square, or jammed up and makes the belt jump of.
Oct 18, 2013 | Dirt Devil 0100 Handheld Bagless Vacuum...
Need to clean roller on classic
Unplug, cut hair on rollers and pull to clean. Remove dust bag and use a bent hanger to pull out the clog from the intake tube, most likely there is paper caught in the hair.
Dec 04, 2012 | Dirt Devil M0100 Classic Hand Vac
Kenmore Intuition Upright Vacuum Logo
43 people viewed this question
Top Kenmore Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you a Kenmore Air Purifier Expert? Answer questions, earn points and help others
