VCR is turning off within seconds of when it's turned on, there is a red rectangle on the screen which does not say anything like it being locked, & a wheel that is continuing to move while it's o
Our VCR is turning off within seconds of being turned on. It has a red rectangle that appears on the screen. It does not say that the machine is locked. And there is a wheel that is moving for those seconds that it's turned on. What can we do? Is it something that can be solved? Thanks!
  • Televison & ... Master
  • 5,397 Answers
It looks like the red triangle might be an indication that there is a fault. It could be something to with the mechanism. I would take a look inside the unit by taking off the top cover. The unit shuts down to prevent further damage.
Posted on Apr 05, 2014
4 Suggested Answers
sonysonyman
  • 68 Answers
SOURCE: More info on Aiwa HV-MX100 not powering up
mechanical fault needs profesional technisian just not to make it worse , regards
Posted on Apr 30, 2007
fairlane
  • 50 Answers
SOURCE: "SAFE"
Greetings Spock! Although I worked for an authorized rca service depot for 12 years, and worked on many, I can't remember the solution to your problem, and Thompson Consumer Electronics (RCA/GE) don't even accknowledge they ever sold vcr's..I went to RCA.com and your model comes up as "does not exist"...Anyway...I know I've worked on that model, and if you have the book, check the section about parental lock, or Key lock...your RCA could very well be Samsung inside, and if so press and hold the tv/vcr button for 5 seconds and that will release the key lock feature. It is there so if you set the timer, or just don't want the kids messing with it, you can lock all the key functions, and the unit will do nothing except display "safe" Hope this helps...Live long & prosper!
Posted on May 04, 2007
pishta68
  • 593 Answers
SOURCE: vcr lockout
use remote and go into record timer option, clear any timer that is active, that should clear up the "lock out".
Posted on May 29, 2008
New DVDs won't play without a loud buzzing sound, and a lot of glitching/jitter on the top half of the screen.
on the a/c adapter, (red yellow and white.. unplug your yellow connector and if that doesn't fix it, then plug it back in and unplug the white one.
Mar 23, 2014 | GoVideo DV2130 DVD Player/VCR
Once the VCR is turned on, it turns itself off.
If there is a mechanism fault on the VCR then the VCR will shut itself down. It sounds like the mechanism might be jammed, it's trying to move to the right position, when power is applied but can't so it stops. One thing that might be wrong is the mode switch might be faulty. This will cause all sorts of thing to happen, including putting on the timer record light even when none has been set.
Feb 16, 2014 | Panasonic PV-V4523S VHS VCR
We have a large screen TV and it displays a solid
your closed caption system is turned onn to its TEXT FUNCTION use your remote to find the CC or closed caption option and turn it off and the block will go away . good luck
Oct 26, 2009 | JVC Televison & Video
Dark Translucent Rectangle appears in front of picture
Go into the customer menu and find the "closed captions" heading. Within the closed caption you will find "TEXT". If you turn off closed captions or the text, whichever you menu lets you do, your rectangle will go away. Hope this helps
Dec 21, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
VCR Lock activated-Can I turn it off?
Turn the VCR on and remove any tape. Press the record button and the VHS/TV button simultaneously. You should see a message saying the VCR is unlocked. It worked for me.
Aug 18, 2008 | Quasar VHQ720 VHS VCR
Bush Video Dvd combo Dvrhs02 Lock Code
Turn the unit on then press the 'vcr/dvd' and 'disc menu' buttons on the unit together and hold down until the unit reboots
Jan 03, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Centrex 80cm locked
there is a button on the remote that has a rectangle shape on it with a + inside the rectangle. Hold it down for 4 seconds or more.
Nov 04, 2007 | Televison & Video
Hyunday HTD21P 21" flat television
hold down the on screen display button (small rectangle inside a larger rectangle) for at lease 10 seconds
May 27, 2007 | Hyundai ImageQuest HQL200NR 20 in....
Something wrong
A jammed or defective VCR can cause this symptom if the TV is turning itself off within about 15 seconds of turn on. Otherwise, it could be anything from a bad capacitor in the power supply to a shorted component in the High Voltage/deflection circuits. In other words, time to replace it.
Dec 18, 2006 | Sharp 13VT-R100 13 in. TV/VCR Combo
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
