Question about Garmin nuvi 1390T Car GPS Receiver
Keeps going off
Plug it in it loads up then goes off then loads up again
  • Mark Fasano
    Mark Fasano Feb 18, 2014
    + 1 for the same issue that just started about a week ago..
My 85 cr250 keeps going through spark plugs quick.
A spark plug should last 20,000 miles or more. When you say goes bad what is happening burnt away electrodes, wet, fouled with metal particles, no spark? Check for the correct plug type in the user manual. Do not use another make. Make sure gap is correct and try bike again. Check plug color it should be light brown/grey, if black you need to check fuel mixture and choke assembly. NGK make Iridium plugs they give better sparks than normal NGK's try these if all else fails. Make sure the iridium[s] are correct for your bike eBay have great deals on plugs.
Sep 23, 2014 | Motorcycles
1999 v6 firebird misfires on #6 cyl when under load, plug was fuel fouled last time I had it replaced, but keeps missing only when under load. no other problems.
if you've changed the spark plug and no difference, then it's time to swap the coil with another cyl. coil and see if the miss goes to the other cylinder, if it does'nt follow to other cylinder, then I would replace that injector !
Mar 18, 2012 | 1999 Pontiac Firebird
I loaded Window 7 on my PC, yesterday. Today it will only go to user password then starts to log on then goes logging off, restarts and goes to user password again. I did a system test and got the error...
Did you download new drivers from your pc's manufacturers web site or mother board manufacturers web site. If you haven't got the mother board drivers, odd things will keep occuring.
Jan 19, 2011 | Computers & Internet
My yoville wont load on myspace, it just keeps showing a stupid white girl dancing for hours
Yeh, me to, but, mine goes the to loading bit, but ehn says, "this server is taking longer then usual, try again" so i click the 'try again' button, and it dose the same fuking thing over again, i mean wtf? SO BUGGING ME
Sep 14, 2010 | Computers & Internet
I started a wash cycle, needed to add more laundry, press the pause/cancel buttom twice, now I can't start it again. When I press the start buttom everything goes blank, all lights go off
Remove the power plug and keep aside. Keep the sart button pressed on to discharge. After 15 minutes switch on the washer while holding the pause/cancel button.
If the set does not come back to life it iis possible that the main board has encountered some errors.
Repeat the procedure after some time.
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wont go past loading screen
shut it off let it sit for like 10 mins then plug everything back in then try it
Apr 20, 2009 | HP Pavilion a1330n (EL466AA) PC Desktop
Samsung hue restarts repeatedly
might be corrupted data or phone just took a dump on you
Jan 04, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Garmin nuvi 1390T Car GPS Receiver Logo
22 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
