Question about Panasonic PV-V4523S VHS VCR
Once the VCR is turned on, it turns itself off.
Hi! We've noticed that once we turn on our Panasonic PV-V4523S VHS VCR, within a couple of seconds, it turns itself off. There is a red rectangle that appears on the screen where the clock is usually lit or the channels appear. There is nothing on the screen that says it is locked. The VCR turns itself off within a couple of seconds. There is also a head or wheel that is continuing to move without any buttons being pushed. There is not any videos in the VCR at this time either. Is there something we can do to fix this or is the machine done for? Thanks!
  • gwenkevin04
    gwenkevin04 Feb 28, 2014
    So, what would you recommend? Should we take it somewhere to get it fixed or just get a new VCR?
  •  Grubhead
    Grubhead Feb 28, 2014
    If you have no skills to fix this yourselves, I suggest you take it to the nearest Panasonic repair shop. Before you do that look it up online to see how much a good second hand model of the same type would cost to buy. That will give you the best idea of how much to spend on a repair. Get an estimate from the shop on how much the repair will cost. If it costs about 3 quarters as much as the second hand to repair, I would look to a new VCR. New Panasonic VCR's are not cheap, but they are a good make of VCR. Hope that helps with your deccisson.
  • Panasonic Master
  • 5,151 Answers
If there is a mechanism fault on the VCR then the VCR will shut itself down. It sounds like the mechanism might be jammed, it's trying to move to the right position, when power is applied but can't so it stops. One thing that might be wrong is the mode switch might be faulty. This will cause all sorts of thing to happen, including putting on the timer record light even when none has been set.
Posted on Feb 28, 2014
3 Suggested Answers
Grubhead
  • 5151 Answers
SOURCE: 1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Posted on Dec 22, 2009
Grubhead
  • 5151 Answers
SOURCE: I'm looking for an instruction manual for a
You should be able to download it for free from the Panasonic website.
Posted on Mar 14, 2010
I need a manual
The Panasonic website has PDF's (free) of nearly all of the models of VCR.
Dec 21, 2011 | Panasonic PV-V4523S VHS VCR
HOW CAN I TURN OFF THE PLAY REPEATS IF I CANT SEE THE MENU DISPLAY WHICH IS DISTORTED? PLS HELP DEVICE : "Panasonic PVV4523S" HOW DO I RESET TO MY VCR'S ORIGINAL MANUFACTURER SETTINGS?
1 - Turn VCR Power on.
2 - Press and hold both PLAY and CHANNEL on the VCR for more than 5 seconds. The power shuts off.
3 - Do “Initial Setup (Ready to Play)” on page 4.
Nov 19, 2009 | Panasonic PV-V4523S VHS VCR
Panasonic VCR Displays "REP"
Press "Action" on your remote control. Go to "Play repeats" and turn it off. "Play" will then replace "Rep" on your display.
Feb 14, 2009 | Panasonic PV-V4523S VHS VCR
How can I remove a stuck video tape from out of a VCR?
You will have to take the cover off. ( un-plug the AC cord)
Look for the loading motor at the back right side.
Rotate the motor and you will see the tray moving thru its cycle to un-load the tape, it does take quite a few turns, its slow.
Let me know if you run into a problem?
Apr 08, 2008 | Panasonic PV-V4523S VHS VCR
VCR acting strange with audio and playing
It sounds like the audio control head is at fault.
If all prerecorded tapes (movies) play with audio level jumping up and down, is is likely that the audio head is dirty. The audio head in the VCR looks very similar to a head of an old audio cassette player.
First, try to clean the audio head by running a VHS head cleanning tape. The cleanning tape will usually clean the path of all tape mechanisms..
Good Luck
Feb 25, 2008 | Panasonic PV-V4523S VHS VCR
Picture flips whill playing tape recorded from cable TV station
All tapes do this, or only ones made on this machine?...accordianman
Feb 13, 2008 | Panasonic PV-V4523S VHS VCR
Panasonic VCR stop
unplug for 10 minutes then replug the cord and see it working regards
Apr 23, 2007 | Panasonic PV-V4523S VHS VCR
Auto-powering off within seconds of turning on
timing out or takeup sensor faulty located next to carriage
Mar 18, 2007 | Panasonic PV-8661 VHS VCR
Panasonic PV-V4523S VHS VCR Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
