Question about Denon AVR-2312CI
Denon 2312ci powers off afterabout a minute with no speakers or other connections. Then it won't power back on. I've let it sit for a day or two then it might power up.
SOURCE: Denon DRA 395 flashing red power light
Needs to be reset or fuse blown. Take to repair shop, cover has to be taken off and fuse replaced. You could fix it yourself but the warranty won't be honored. Do it yourself electronic shop should have a replacement fuse, may have to be soldered in place. Repair shop, should cost around $30.00 to $45.00 to fix, price of fuse $4.00 to $6.00. Your choice.
Posted on Mar 27, 2008
tech48
  • 624 Answers
SOURCE: Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Posted on Jun 22, 2008
  • 7 Answers
SOURCE: Denon AVF988 to power amp to whole house speakers
jbell302, Check both remote spkers for operation from the A spks output if good, switch B remote spks to A main connect & main A spks to the B remote connection on the Denon spks outputs . Most amp sources do not like different ohm spks types & different cable or spks A-B. lenghts, because this makes up to resistances problems, making the amp to work harder & understanding what is going on. THE AMPS PROTECTION CIRCUIT IS AT ALERT & TRIES TO BALANCE THE RESISTANCE VOLUME. Best move is to try use the same spks. lenght & a higher qauge wire; 12.14.18qa. to better balance the output volume! All matching spks. pairs would help alot as well!
Posted on Feb 04, 2009
dunnbiker
  • 8546 Answers
SOURCE: Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Posted on Feb 23, 2010
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
No sound from internet radio
I assume you have connected your amplifier to your local area network so that you can access internet radio. If not, you need to connect the RJ45 ethernet port to your router, then log on to your router to confirm that the receiver is connected as a client. I have done this with my Denon receiver and it works perfectly. Please feel free to ask if you need further assistance. Cheers, Don.
Dec 07, 2013 | Denon AVR-2312CI
Gateway M 6843 won't turn on
You may have already done this, but remember many laptops require that you remove the battery for about 30 sec. as
well as disconnect the AC power to reset them.
Always try this when everything appears completely dead.
Source: pcsupport.com <<<and it's worked
Aug 28, 2012 | Gateway M-6843 Notebook
Restarting avr-2312
I've had THE SAME PROBLEM ! Neither official servise, nor internet could help me. The solution was problem with POWER CABLE! When tested it by TESTER it was ok, with no sign of a problem. I've tested everithing byt nothing could help me :) After all test I've noticed that when I've touched the power cable the problem occurred. After changing the power cable everithin WAS GREAT.
Aug 13, 2012 | Denon AVR-2312CI
Denon 1907 power light blnks red
You have a bad "Driver:" or Power transistor in the amp.
I usually replace the two power amps and the driver amp/amps at the same time. The pairs are usually matched, and since one interacts with the other, a bad driver will weaken the power amp pair, and vice versa.
The overload is the transistor breaking down 9which tends to generate excessive heat), Then the thermistor on the amp pair heatsink senses this condition and shuts the amp down. (NO - replacing the thermistor eill not generally solve this issue, especially since the thermistor qwill survive a temp rise well above what the tranisitor pair will).
Jul 24, 2012 | Denon AVR-1907 Receiver
Similar situation as previously described with the Denon AVR-1508, but mine will shut off after about 10-12 minutes the first time around and then ~2 minutes after it is turned off and then back on. Unit...
Most new receivers have a fan on the back, if you have one check to make sure it is working, most won't activate until the unit gets warm, other issues are bad solder connections on the audio outputs causing intermittent shutdown, as a final inspection check speaker connections to the receiver and speakers.
Sep 18, 2011 | Denon AVR-1508 Receiver
Fuzzy sound from front speaker
you have a small short in the connection of the unit.. it may be just bulid up which can be fixed by just blowing compressed air thru it. but if it more than that take to a repair shop as it could be an intenal problem
Apr 27, 2009 | Denon AVR-3300 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Denon AVR-1906 Reciever is not working. Was watching a movie and then it suddenly shut off. Now, the power light is blinking red. When I try to power it on again it starts to boot up but then turns off...
speaker terminal are short circuit,switch power off connect speaker properly then switch power back.
-the ventilation holes of the set are blocked-turn power off and make good ventilation around leave the set to cool and turn power back.
-the unit is operating at continuous high power turn it of and allow for cool down and switch it back.
Jun 01, 2008 | Denon Audio Players & Recorders
Denon AVR-1905 Receiver
Hi again,
Any new developments?
May 25, 2008 | Denon AVR-1905 Receiver
Denon AVR-2312CI Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
