Question about ifrogz Audio Players & Recorders
Headphone speakers not working
Headphone is not working
My laptop's audio software is installed correctly. it is working well in headphone but when i unpluged the headphone leaptop original speaker is not working
the problem is likely your speakers. consider the extension speaker or speakers use the function bound to perform troubleshooting
Mar 09, 2012 | Dell Computers & Internet
Headphone jack not working
I find that there is a problem with your headphone speaker.
Try with some other headphone, even if it is not working, then you need to take it to the service center.
Cheers,
Mr.Maduraikaran.
Jan 10, 2012 | Acer Computers & Internet
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
Power amp r b 981 no power to the speakers. Pre amp seems to be ok. Headphones work.
Check the headphone socket if it cuts out the speakers (normal use) when you plug the headphones in. If it doesn't and you have a switch to switch off the speakers when listening to headphones, check the switch. It may be physical damage or dirt causing the problem, or even loose soldering on the headphone socket. But the fact that headphones work shows the main amp is working. Also make certain the speakers are connected properly.
Sep 28, 2010 | Rotel Audio Players & Recorders
Do headphones NOT work in these speakers or do they have to be jbl brand headphones?
Not really, see the headphone connector if it fits the unit. If it fits but doesnt work then the headphones may have a problem. HOpe this helps and have a good one!
May 01, 2010 | HP JBL Platinum Computer Speakers
Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Apr 05, 2010 | M-Audio Studiophile DX4 Computer Speakers
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Nov 01, 2007 | Logitech X-230 Computer Speakers
Open Questions:
Top ifrogz Audio Players & Recorders Experts
 Grubhead
Grubhead
 binay biswas
binay biswas
Tom Chichester
Are you an ifrogz Audio Player and Recorder Expert? Answer questions, earn points and help others
