Question about Janome Sewing Machines
Raising presser foot on Janime 2212
I need help raising my presser foot right now all I can fit though bottom of presser foot is very thin fabric
    Novelist:
  • 268 Answers
Http://content.janome.com/userfiles/file/Inst%20book_%202212%28En_Sp_Fr%29.pdf
See p. 10 of the manual.
The presser foot lifter is on the right side of the leftmost part of the machine, towards the back of the machine. Press up to raise it.
Posted on May 22, 2014
  • 33 Answers
SOURCE: How to connect the walking
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Posted on Sep 05, 2008
JeremySew
  • 65 Answers
SOURCE: need presser foot holder
Here are the parts you need:
Brother Sewing Machine Presser Feet & Shanks
Posted on Jan 05, 2009
RickE1
  • 202 Answers
SOURCE: presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Posted on Jan 08, 2009
  • 24 Answers
SOURCE: Can I loosen the presser foot so knits will not stretch
Pressure on the pressure foot can be adjusted on some machines by turning the knob on the top leftside of the machine directly above the needle assembly. Look for a knob that has fabric types on it and adjust accordingly. Also check your thread tensions.
Posted on Feb 09, 2009
Jannarama
  • 14 Answers
SOURCE: feeder feet under presser foot clicked down not able to get back
The switch for the FEED DOGS is on the left side of the machine.
Posted on Mar 19, 2009
Loose stitches 2212
Be sure to Always Raise the presser foot when threading the top thread. This may help with your situation.
Aug 27, 2017 | Sewing Machines
Elna 5200Q The material is bunching up in front of the feed dogs
Are the feed dogs actually raising, moving, and dropping (raise the presser foot and hand-rotate the handwheel and watch how the feed dogs are moving)? If not, check to see if the stitch length is set well above the zero (which means it sews in place)? Perhaps the presser foot pressure is set too firm and is preventing the fabric from moving under the foot.
May 17, 2017 | Elna Sewing Machines
Tension on the side does not release the cotton when machine is stopped, making it difficult to pull out the job.
Be sure to always RAISE the Presser Foot when threading the machine or when removing fabric. When threading or removing the fabric, try raising the needle to its highest point. Raising the presser foot releases the tension disks. When the presser foot is down, the tension disk is engaged and will not release the thread.
May 23, 2016 | Sewing Machines
Machine will not sew its is looping under neath from top cotton
Remove the upper thread from your machine.
RAISE the presser foot and then rethread from the beginning. Raising the presser foot releases the tension disk so the thread will seat properly). Also, verify that the threading steps are correct (consult the threading instructions).
Check that the bobbin thread has been loaded in the bobbin case properly and threaded through the tension spring.
Test. If the upper thread is still showing under the fabric, tighten the upper tension disk until the upper and bobbin threads meet in the middle of the fabric.
Feb 03, 2016 | Janome Harmony 2041
Lots of thread on bobbin side
If it is the top thread making gobs under the fabric (thread nesting or bird nesting), usually the upper tension needs to be tightened.
Install a brand new needle. Raise the presser foot and re-thread from the beginning. (Raising the presser foot allows the thread to seat properly in the tension disks.) Check your manual to be sure you are threading correctly. Re-test the stitch and tighten or loosen the upper tension until both upper and bobbin threads meet in the middle of the fabric.
Nov 27, 2015 | Sewing Machines
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
Why does the backing gather up even though it is penned and sprayed with quilting spray
Presser foot tension is to low for the weight/finish of the fabric, or bottom dogs are worn.
  • The feed dog feeds the fabric under the presser foot while you guide the fabric.
  • The feed dog regulates the stitch length by how much fabric passes under the presser foot as the machine stitches.
  • It is important for you to not push and pull the fabric under the presser foot. Allow the feed dog to move the fabric, so that you do not bend and break sewing machine needles.
Hope this helps.
Feb 09, 2011 | Sewing Machines
Trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Feb 21, 2010 | Husqvarna Sewing Machines
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Jun 24, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
69 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
