Question about LG Heating & Cooling
Remote controls i have two air conditions with two remotes both seem to be not working at the exact time so i changed the batteries and still not working
  • 3 Answers
Seems like its not the remotes, If both units are not responding I would first make sure the circuit breakers havnt turned the power supply off. Most units have a manual button you can press try that next and see how you go.
Posted on Feb 17, 2014
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
  • 400 Answers
SOURCE: Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Posted on Mar 05, 2009
SOURCE: Sharp A/C remote CRMC - A310JBEO RO3 (AAA) 2PCS is not working
There are two AAA batteries hidden below the keypad under the sliding cover.
Gently prise off cover to real batteries, and replace them.
Posted on Jul 03, 2009
SOURCE: Changing the battter of the remote control
Slide the cover down as far as it will go. Now using your fingernail, gently lever the cover off from the base, it will click out without much force. This is a stupid and confusing design and should be changed.
Posted on Apr 09, 2010
TX_AC_Man
  • 107 Answers
SOURCE: Can I download an English
yes.. go to www.carrier.com and then click residential and then find the proper equipment that you have
Posted on Sep 01, 2010
Why when pressing the on button the airco doesn't come on
Did you changed the batteries? 99% of the time the remote problems (not working) is due to dead batteries.
Assuming you have new batteries, does the remote gives you any codes or displays abnormally? If this is the case, you might need to replace your remote. You can buy a universal remote for A/C units, either through your HVAC Repair Company, or wherever they sell A/C parts.
Sep 15, 2014 | Panasonic Heating & Cooling
Hi.... My Air conditioning remote control AR-DL1 doesn't seem to be working.It's been working on and off for a while,but now ....Nothing at all ( I changed the batteries also ) .Since I don't know if it's...
Remove batteries and keep for 5 minutes. And also remove DC wire plugged in display sensor in your indoor unit. Now, plug again DC wire in same position and also put batteries in remote. Power on and try now. In many units, this type of resetting would help. If still problem, check remote thr' camera mobile by pressing any button in remote. If ultra light flashes, remote is o.k.You have to repair/replace PCB only. If no ultra light, replace remote.Thanks.
Feb 01, 2011 | Heating & Cooling
Remote lights up as if it is going to work however it won't do anything batteries are new, so that is not an issue almost seems like it needs to be re programmed or something my 2 year old could have...
Without knowing the exact issue I can only provide general information. Since it seems like it may be a satellite address problem, I can definitely help with readdressing the remote.
To program remote to Receiver:
1. Access System Information from main receiver.
2. Note the number on the bottom by Primary Remote Address/Secondary Remote Address.
3. Hold SAT until all lights turn on on top of the remote.
4. Enter a number between 1-15 and press #.
5. Press record 3 times after it finishes blinking and the number by remote address should change.
Tommy Faust
DISH Network
Aug 31, 2010 | DISH Network IR Remote Control
Kenmore a/c remote control doesn't work
Google AirConditioning remote controls. Go to parts warehouse and check there. I have purchsed two remotes for different AC units on line for about 50 dollars.
Jun 08, 2009 | Kenmore 75085 Air Conditioner
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Samsung remote control
Remote control problem: your going to laugh at this but this was an easy fix, after my husband told me that there was something wrong with it, I tried to use the remote and he was right, it wasn't working. I changed the batteries that evening and sure enough it still wasn't working. The next day I had a closer look and thought that it wasn't right that a new t.v. remote wouldn't work, and lo and behold the problem? My housekeeper put a picture right in front of the electric eye of the t.v.! Guess what, it works quite fine again, thank-you for your time, and I am glad that it wasn't anything major. Peggy
Jul 22, 2008 | Samsung TV Remote Control
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Jan 01, 2008 | Heating & Cooling
Air conditioner remote
- check if the battery is still good
- check if the receiver of the unit is clean and no obstruction.
- Some of remote control have a reset switch, every time you change it with battery you have to reset it.
- Some of remote control have A and B selector at board and remote control, check this if they set at the same frequency.
- To check if the remote control still working you have to test your remote control to other unit with same model as yours. If its not working then replace your remote control. But if its working then you have to replace your receiver board.
- Some remote control have to be reconfigure so you have to read your manual.
Dec 29, 2007 | Heating & Cooling
Remote Problems
do you have any CFL's in the room try turning these lights off as I have seen these effect some remote control systems
Feb 27, 2007 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
