Question about Pool & Spa
South seas spas
My temp button will not advance the temp up. all other controls work fine. stuck on 97 degrees. easy solution, or do I need a tech to look at it. South seas from lighthouse.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,448 Answers
Need more info. will temp lower? if temp lowers try setting up to 104 if desired temp will not increase sounds like you need temp adjustment switch if desired temp goes up to 104 but water doesnt
sounds like temp sensor if temp sensor is good heater element
Posted on Mar 13, 2014
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
Spa was below temp, now it heats and won't shut off.
Is your spa overheating, heating up past 104 degrees?
If so, you have a contactor (or relay) stuck shut and the spa should go into OH at 108 degrees.
d
If your hot tub is only heating to 104 or what ever temp you have it set at and the motor runs 24 hours a day there are a couple of things you'll want to check.
First, make sure that you do not have the pump set to run 24 hours a day.
Second, you'll want to see if the pump icon is lit up on the control panel. You will want to check to see if the icon is on while the spa is supposed to be resting. During filter cycles the icon will be lit. If you are not in a filter cycle and the pump is on while the icon light is off, you have a stuck contactor (relay). The relays can be found online for less then a couple of dollars.
If you have any more questions feel free to ask.
Feb 23, 2015 | Dream Maker Spas Dream Maker Spa - X500...
I have a zoneaire sea ptac unit that wont produce heat on the high setting but will on the low setting... would this be a bad capacitor?
Pls note the heat temp that you kept must be 3 to 4 degrees C* between room temp and required temp.
And also number-wise keep down will be high cooling and keep up will be high heating.
Tnx
Nov 15, 2013 | Carrier 52PQ307 Wall/Window Air...
How to I increase the temperature to 101 on the drreammaker spa fantasy model?
This may be a little late as you may have already found the answer. But most "Fantasy" spas have "Balboa" control system. They are either a heat control knob, or Up/Down arrows on the spa side control system.
If you have the know & it is all the way turned to max position, and still not hot enough, then you may well have a faulty "Temperature Sensor". Get a replacement from your local DreamMaker dealership. Easy to replace.
Dec 20, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
My indoor RS4 panel says the spa is heating, and then reached 101 degrees. But when we got in, it was only 97 degrees and the outdoor panel displayed 97 degrees. Everything else seemed to be working fine.
If the heater is set to 104 then this is probally your Aqualink temp sensor. This is mounted in a pipe with a stanless steel clamp holding it in place. If you follow the wire back to the controler box it just unplugs and the new one goes right back in. Easy to do and the part is inexpensive.
Sep 26, 2009 | Jandy Aqualink Rs4 One Touch Control...
Freezer works fine--Fridge Side Not Cooling Properly
I am sending you a link below to download the manual for your model. There are too many Q&A to do this here and on this page. The manual has some self diagnostic test you can do yourself through the control panel. These are very good refrigerators and they are backed by Maytag. The only problem is they are complex. You can try to find answers and if you have questions I will need to be contacted by email because Fixya has not been sending out anyones responses lately. They know about the problem. Sea Breeze
appliancepartsse@yahoo.com
http://www.servicematters.com/maytag_library/docs/SAM0074.pdf
Jul 16, 2009 | Samsung RS265LABP Side by Side...
Pool & Spa Logo
208 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
