Question about Carrier Heating & Cooling
My carrier furnace 59sc5a has a yellow light in front is that normal
2 Suggested Answers
SOURCE: Carrier furnace burner will not on with front panel close.
If i recall right this is a combo gas pack that sits outside, there are no air intake vents on the front panel,but there are intake vents on the side. Make sure they are not blocked also check to make sure when you put door back on that its not crimping any wires.
Posted on Jan 10, 2010
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
My Carrier Infinity 96 air conditioning is not working. The status code led is yellow and on steady. Any ideas??? Thx!
That light being during cooling means that something is pulling too much current. Check the relay in the outside unit (warning high voltage) and if you have a condensate pump attached to remove water, make sure it is working.
http://www.hvac.amickracing.com/Furnace%20Info/Variable-Speed%202-Stage%20troubleshooting.pdf
Jun 13, 2015 | Carrier Heating & Cooling
I have a carrier 58RAV050-12 and my furnace won't turn on. It was working earlier today but it just stopped. Any suggestions as to why?
Check the pilot lt. If its out shutdown your furnace and call a repairman. If the pilot light is on, the flame sensor might have gone out. It's a long silver sensor that sits in the pilot light flame and senses when the flame is present. If it isn't working the furnace will automatically shut down.
Nov 04, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Infinity 96 gas furnace with no heat
That means that the furnace is throwing a code to trouble shoot whats wrong. Most of the time, furnaces will have a code list on the inside of the door cover to explain what each code means, some of them don't. Its hard to say what it could be without knowing where to start. However, answering a few questions with someone knowledgeable over the phone if possible could help speed things up, but it would involve you being at the furnace and seeing what happens before it throws the code. If you do have a code list, this would help tremendously.
Feb 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier super saver furnace keeps going on and off
Sounds like the flame sensor is dirty or bad. This sits in the burner flame when the burners are running. This usually has a single white wire connected to the back of it.
Jan 03, 2010 | Dayton Gas Furnace Heater
Sounds like a combustion air issue and by removing the front panel it lights and runs. Is there a PVC pipe connected to the cabinet that may have a blockage in it? There may be 2 pipes, one for exhaust and one for combustion air. Would not hurt to check both.
Jan 02, 2010 | Carrier Heating & Cooling
Does not find furnace
Make sure all wires are hooked correctly ABCD should match. The Kill all power try again. When Infinity control is hooked up correctly it by passes all dip switch so that it can communicate with the tsta furnace and outsid unit. Rus
Apr 30, 2009 | Heating & Cooling
How do I relight Pilot for a Model # Carrier 58GP100-3 Furnace?
as the unit is very old there is no specific manual available for it to guide you but i will give u some link for extra help.
Nov 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
332 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
