Question about Whirlpool GEQ9800P Electric Dryer
Whirlpool dryer doesnt heat, time and shut off when you open the door
Doesn't heat up,timer doesn't count down or shut off when door is opened
    New Friend:
  • 45 Answers
Check the coils - they are inexpensive and very easy to replace.
Check YouTube for a tutorial.
Posted on Jan 18, 2015
  • Whirlpool Master
  • 2,248 Answers
If you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Posted on Feb 16, 2014
SOURCE: whirlpool dryer problem
dryer works but does not heat up
Posted on Aug 11, 2008
SOURCE: whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Posted on Feb 02, 2009
spc_jschuck
  • 13 Answers
SOURCE: Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Posted on Apr 01, 2009
App King
  • 55 Answers
SOURCE: no heat/wont automatically shut off.whirlpool
The unit will continue to run as long as there are wet clothes in it. You will need to check the heating element and the two wire fuse on the top part of the heater housing. If either one have no continuity through them, you will need to replace the one that doesn't. This will fix your problem.
Posted on Jul 23, 2009
  • 523 Answers
SOURCE: My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Posted on Jun 08, 2010
Dryer runs with no heat and never shuts off on its own
what are you running it on?auto or more or less,if so the timer will not advance to off without heat,usually the heat comes on,the dryer heats up until it reaches temp.the heater shuts off and then the timer will start to advance to off,when the heat comes back on the timer will stop advancing and the heat will come on,it will do this until the clothes are dry,so no heat the timer will not move,now if you put it on time dry the timer should count down no matter what just like a clock.if you open the door and look around the opening where you put the clothes in you'll see a tag with the model number send this and i can help you.
Oct 08, 2013 | Kenmore 63942 Dryer
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Shuts off during autodry cycle. stays on during timed cycle but clothes are wrinkled ans too hot at end of cycle.
if it works on auto but not on time you have a bad timer,it's not counting down,it's better to use auto anyway,when the clothes dry the dryer shuts off on it's own,this way your not using extra electricity,if your clothes dry in 30 minutes and it's on 60 minutes it will still run after the clothes are dry on auto it doesn't.if you open the door and look around the opening you'll see a tag with the model number,your missing a couple of letters on the model number.
Mar 05, 2011 | Whirlpool LER4634J Electric Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool model LER4634PQO dryer. Will not heat. Dryer also will not shut off. Timer is running but will not shut off at the end of cycle. Can manually shut off and opening the door also shuts dryer off.
96f3244.jpgEither the top limit or the element is open, that is why the timer motor is not advancing. The small wire on the bottom limit powers the timer motor. The fuse is not blown because the dryer runs. The fuse has smaller wires and is tied into the door switch wiring and when it blows it is as if you opened the door. If the top limit is dead it is because of a vent blockage. I have repair photos HERE
Feb 28, 2010 | Washing Machines
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Replaced timer however time does not count down and dryer won't heat up
one thing to check it the voltage coming into the unit make sure you have 220-230 volts at the plug if so you want to open the back little panel where the cord goes in and check your terminal block and cord connection PLEASE unplug b4 you open the panel A dryer will still tmble but wont heat or advance if that leg(110volts) is not there and the other one is
Jan 20, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
171 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
