Question about Honeywell Heating & Cooling
How to repair Honeywell HZ-341 BW Digital Oscillating Ceramic Heater
forgot
  • 17 Answers
SOURCE: honeywell hz-341-bl ceramic heater
take a heat gun or a blow dryer and preheat thermostat and any conductive leads.
after a few pre-heats it will get the idea!
Posted on Nov 17, 2007
SOURCE: Honeywell Ceramic Heater (HZ-370) does not swivel anymore
The instructions say this unit is not designed to be taken apart and they are right. Although i was able to unscrew the back plate and slip my hand into wipe the swivel base. It turns once again and my wife thinks I'm a genius.
Posted on Dec 22, 2008
  • 36 Answers
SOURCE: Hi, Honeywell (HZ-341BL) Ceramic Heater stopped
when most ceramic room heaters stop working, the blower is clogged with lint and dust from floor use . get an air compressor, or a can of air. take unit outside using a small head philips driver remove screws while laying on an old sheet .disassemble cover carefully and blow dust away from you and clean blade without bending with a toothbrush in vinegar water not gettting any liquid on the electrical parts. reassemble. thanks karl
Posted on Dec 14, 2009
klipsan
  • 64 Answers
SOURCE: I need a tilt switch for the honeywell HZ-341-bl
Hi, Jim...
I'm presuming that your heater has a tilt switch that isn't working. Is this right?
Tilt switches used to contain mercury (which has been phased out because it's so toxic). They now contain ball bearings... which may have gotten frozen (especially if you live in a high-humidity area).
I'd first of all open up the heater, identify the switch (generally black plastic, around 1" long by 1/2" wide - something like that) and rotate the heater back & forth... listening for the sound of a ball bearing rolling back & forth. If you don't hear any sound, you can try CAREFULLY knocking the switch housing with, say, a ball-peen hammer to loosen it up.
If this doesn't work, you will probably want to replace the switch. You can find them on Google, ranging from $2-6. If you're handy with a soldering iron, you can easily replace it yourself. Otherwise, find a friend (or take it into a shop) for a very quick & easy fix. Don't forget to epoxy the housing of the switch to the heater, so it doesn't rattle around!
Posted on Mar 02, 2011
  • 3315 Answers
SOURCE: How do I clean a
if you have a vac with blow on it , i would blow it out , or use a air line very gently , to blow the dust out .
Posted on Mar 03, 2011
Testimonial: "Practical, good advice. Thanks!"
I need a tilt switch for the honeywell HZ-341-bl porable heater. Where do I find one and how much do they cost? Jim
Hi, Jim...
Mar 02, 2011 | Honeywell (HZ-341BL) Ceramic Heater
Hi there my dog chew the eletric cord on my honeywell hz-341bl heater. what kind of cord should i use. thanks.
If you look at the cord it should tell you what kind of wire it is....... If not most of the little heater use 16ga stranded wire rated for 105degree C at 300 volts.
Dec 19, 2010 | Honeywell (HZ-341BL) Ceramic Heater
The heater no longer moves from side to side. It's an oscillating heater. How can I fix this?
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Oct 05, 2010 | Honeywell HZ370 Space Heaters...
THE HEATER RUNS FOR 2-3 MINUTES AND AUTOMATICALLY
Thermal safety is tripping, clean it out , no repairs viable for theses units,
May 23, 2010 | Honeywell HZ365 Ceramic Compact Heater
Hi, Honeywell (HZ-341BL) Ceramic Heater stopped working. Can i get help
Dec 14, 2009 | Honeywell (HZ-341BL) Ceramic Heater
Need set of instructions
Fixya can't send instructions but you can try Googling (Honeywell)(HZ-7020)(manual) without parens.
Dec 23, 2017 | Honeywell HZ-7020 Compact Heater
Dec 21, 2008 | Honeywell HZ-370 Ceramic Heater
Honeywell hz-341-bl ceramic heater
Nov 15, 2007 | Honeywell (HZ-341BL) Ceramic Heater
Similar model compact heater will not "power up" after storage
they is no reset internal the electronic circuit is deferctive some electronics parts need no be changed. i have fixed one and modify it to be more reliable.
Oct 01, 2006 | Honeywell SureSet HZ-339BW Ceramic Compact...
Heating & Cooling Logo
70 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
