HOW CAN I CHANGE THE BULBS FOR THE MAP LIGHTS AND THE CIGAR ASH R
By map lights I assume you mean the ones at the top of the windsheild on the ceiling? They are easy, but it takes a lot of force to pry the assembly from the ceiling without damaging anything.
First make sure they are not hot, so make sure the ones you touch have been off for at least a few minutes. The whole assembly comes off of the ceiling, just pry back the edges to get a good grip and pull down. It should come straight off. Then pull the old bulbs, wipe the new ones and install them with a lint free cloth. The light cluster will press back up into the ceiling.
For the ash tray light, it gets a bit more complicated. The light is under the center console. With the gray interior in my car, the console top is black, and that's what you're prying up. You can pull (pry) the center console straight up, and tilt it to the side, where you can look in from the side and get to the bulb. It's a little thing just where you think it would be. Again, install without getting oils or fingerprints on it, and if you do, wipe them off. The console will press back down with a little wiggling.
