N
Norman Stoddart Posted on Feb 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change language on IP6600D - Office Equipment & Supplies
AYYU
Level 2:
Guru:
  • Expert 377 Answers
  • Posted on Feb 17, 2014
AYYU
Expert
Level 2:
Guru:
Answers
377
Questions
0
Helped
105080
Points
869
Is it just the language which has changed or you see any error message on the lcd panel
To change the language settings press the up/down arrow key to select language selection and then press ok.
press the up/down arrow key to select language english and then press ok.
If you want you can reset all setting to default factory settings.
press the up/down arrow key to select reset settings and then press ok.
press the up/down arrow key to select yes and then press ok.
hope that it help
How do I fix a Canon pixma ip6600D printer?
ALARM LIGHT which always glows - RAM error (logic board is dead)
Printer screams when printing
Check the pulleys on the belt which moves the print carriage.
Put a drop of oil on them. Noise should stop
Also please get the service manual for iP6600D from below link it will save you time and money
Canon iP6600D service manual:
http://goo.gl/jov61t
Thanks
2helpful
2answers
The pictures are coming out pink
This is usually due to ink cartridges going bad or being empty. If you have not changed them, this is the first thing to do.
I hope this resolves your issue. Please let us know if you have any further questions.
Canon pexma ip6600d photo printer
my friend who is a computor t echnician came to see if he could fix it and he did. he had to go into my pixma ip6600d photo printer from the back of it and tilt it , he then discovered one of the inks were not fully in and thats why it wouldn,t move, he then pushed down on top of the 6inks with a pencil and the inks were all even and they started moving freely again. I hope this works for others as it is a great photo printer.
Error code 5100 on my Pixma iP6600D.
I had the exact problem described and it was the following:
one of the ink cartidges had popped out of place "inside" the printer housing on the right hand side, and was catching as the printer tried to start up.
By using a thin object such as a ruler, I could press the ink cartridge back into place to allow the ink cartidges to come out from the printer side area. Once out I properly reseated the ink and all seems fine.
Canon PIXMA iP6600D
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=184&modelid=11864#SupportDetailAct
2answers
Canon printer error 5b00, Absorbers full.
Check your power supply lines are clear and in good condition. Also make sure every plug point is well graounded beacuse this may interfere with any electric/electronic device and cause it to malfuction. Check your USB ports for physical damage. The errors you see may be accidental.
k24674
ADMIN Andrew
ADMIN Andrew
