Question about Simplicity 7850 Premier Bagged Canister Vacuum
Where is the thermal reset switch on the Simplicity Sport
Simplicity symmetry vacuum stopped working
There is a reset button on the back that trips if the vacuum gets hot.
Jul 27, 2014 | Simplicity Vacuums
I turn it on and nothing happens,
I would double-check the seating of the bag. Some machines have a lockout switch that keeps you from running the vac with a bag incorrectly installed (which would then suck dirt into the motor).
Mar 16, 2014 | Simplicity Type S Sport Vacuum Cleaner...
Vacuum will not reset
Check the switch and cord
Sep 22, 2013 | Simplicity Vacuums
Problem with fuse
Depending on your model, most machines are equipped with a thermal sensor not a fuse. Machine will over heat if clogged. Check for clogs.
Jun 04, 2012 | Simplicity Vacuums
I have a simplicity spb250 and all of a sudden it shut off and does not turn on. Any thoughts?
Several possibilities for this situation. It's possible that there's a break in the power cord somewhere, not necessarily a noticeable break, but a break none-the-less. It's possible that there's a reset on the motor to protect it from overheating. The switch may be broken inside. I'd say there's a good possibility that you're going to need to bring it to a good sweeper repair shop in your neighborhood.
Jul 03, 2011 | Simplicity 7250 Deluxe Vacuum
I have a Hoover Mach 2.7 Windtunnel that shut off during use and wouldn't turn back on. Was doing kitchen floor and running fine. Though a breaker tripped but didn't...what could it be?
It sounds like your thermal reset switch inside of your Hoover may have gone bad. When a vacuum cleaner doesn't turn on it, it's either caused by one of four things.
  1. Electrical Short in your Cord.
  2. Plug has gone bad.
  3. Motor of your vacuum is faulty
  4. The On / Off Switch has gone bad, and/or your Thermal Reset Switch has gone bad
Since this happened while you were vacuuming, I would guess that this is either your electrical plug that's shorted out, or that your thermal reset switch has shorted out. Your model Hoover was built with a protection system that is supposed to automatically shut down your machine if it senses any excessive heat. This mechanism is controlled by a Thermal reset switch which is located in motor compartment. This part is notoroious for failing, even when there's no overheating that's occured.
Before you disassemble the entire machine to check this part though, I would try testing the On / Off switch in your machine, as well as testing the electrical cord, which will also let you know if your plug has gone bad.
Here's a link to a solution I've done here on FixYa explaining how to check the On / Off switch;
http://www.fixya.com/support/r4530569-replace_off_switch_hoover_windtunnel
While you have this apart, you can use the same electrical tester to test your cord. Simply put one end of the test into the terminal from the switch, and the other end of the test on one of the metal prongs that plugs into the wall. See if you have continuity here, if not, switch to the other prong of the plug and see if this helps.
If not continuity, this means your plug, or your cord has failed. If you do have continuity, this means that it's either the On / off switch, or the Thermal Reset Switch that's gone bad.
Here's a link to the solution that I've done on here showing how to replace the Thermal Reset Switch on your vacuum cleaner:
http://www.fixya.com/support/r4999778-replace_thermal_overload_switch_hoover
If you'd like some more help diagnosing this vacuum, please feel free to just use the comment field on the bottom of this page. I'm always happy to help you do some more advanced diagnosing, or answer any questions you may have.
If you found this solution helpful, please be so kind and rate this repair helpful, or leave feedback for me. This is greatly appreciated by the FixYa community. Thanks so much,
Chris Jones
GoVacuum.com
Jan 10, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Simplicity model 6970 upright vacuum. It picks up great and there is no smell but it will over heat in about ten minutes and shut down. There are no clogs. Once cool, I hit the thermal reset on...
It could be electrical on the inside of the vaccum or your belt is the wrong size therefore making it over heat. Hope this helps?!
Please rate and comment - Thank You
Sep 23, 2010 | Vacuums
Simplicity 7 Series Vacuum. Suddenly stopped.
There is a thermal reset button on your vaccum. It is on the rear of the unit, just below the attachments and next to the sticker with the serial numer etc on it. The vacuum is designed to turn itself of if too much heat gets built up to prevent it from "burning up."
Dec 13, 2009 | Simplicity 7850 Premier Bagged Canister...
Simplicity 7850 Premier Bagged Canister Vacuum Logo
44 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
