Question about Husqvarna Sewing Machines
Husqvarna #1 sewing machine powers on, then cuts off
Before this started happening, she sewed just fine. then I changed thread and it started breaking. Then it cut itself off.
    Scholar:
  • Husqvarna Expert
  • 104 Answers
Can you turn the handwheel without a great deal of effort? If so, it sounds to me like your motor may be drawing excessive current and the machine is shutting off so as not to burn out the circuits.
Posted on Apr 14, 2014
Testimonial: "thank you. I will give this a try and see what happens."
Storma
SOURCE: Upper Thread Breaks!!!
Hi, here are some reasons why the thread is breaking :-)
  • Threading is not correct.
  • Thread has a knot in it.
  • Thread tension is too tight.
  • Needle is bent or blunt or has a sharp eye.
  • Needle is wrong size.
  • Needle has been inserted wrong.
  • Needle and thread does not match.
  • Starting to stitch too fast.
  • Thread take-up lever has not been threaded.
  • Hope this helps.
    Posted on Jan 14, 2009
    • 323 Answers
    SOURCE: Thread breaking.
    Rethread the machine following these directions:
    all machines thread the same. TTN tension, take up, needle.
    Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
    (To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
    Remove the bobbin case and bobbin. Pull on the bobbin thread to make sure it doesn't pull too hard. It should have some tension on it but not a lot. Insert the bobbin and bobbin case into the hook assembly and pull on the bobbin thread again.The tension should still be about the same. If it is tight, you need to look at the bottom of the pin that the bobbin case sits on and see if there are any threads looped around it. If there are , you need to remove them.
    Hold the top thread , turn the hand wheel and see if the thread is catching someplace around the hook assembly. If it pulls the thread up easily, put some fabric in it and see how it works.
    Make sure the thread is through the take up lever.
    sewman7
    Sewman7
    Posted on Jul 10, 2008
    • 10 Answers
    SOURCE: Husqvarna Sewing Machine starts sewing when power switched on
    The problem is probably the foot control. The little wires wrapped around the insulator have broken and are shorting against each other or the cord itself has a short. You can purchase an aftermarket foot control at your local shop, this is the cheapest way to try first, if that does not correct the problem replace the cord.
    Posted on Jun 30, 2009
    • 152 Answers
    SOURCE: Sewing thick fabric and machine won't send it through
    Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
    Posted on Oct 14, 2009
    wcbotha
    • 92 Answers
    SOURCE: Won't sew
    Give more info. Do the motor turn? is the machine stuck? or do every thing work but it do not sew onto the material? We got 9 machines that we work with every day and we repair it as well. E-Mail me and give more info and i am sure I can help. Willem an Fienie South Africa ( wcbotha@yahoo.com )
    Posted on May 12, 2010
    My Husqvarna Opal thread cutter is not cutting the thread from the bobbin.
    Huskies are excellent machines. Guessing this is a serger? Doesn't matter. Very likely you could ask Husqvarna.com. Likely, something is a bit out of sync. Or - all sewing machines are 'picky' about being threaded correctly. You might check that.
    Jan 23, 2018 | Husqvarna Sewing Machines
    Thread keeps breaking using husqvarna
    try these suggestions
    The needle thread breaks
    1. the needle thread is not threaded properly
    2. The needle thread tension is to tight
    3. The needle is bent or blunt
    4. The needle is incorrectly inserted
    5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
    6. the threads were not drawn to the rear after sewing
    7. The thread is either to heavy or to fine for the needle
    Oct 30, 2012 | Husqvarna Sewing Machines
    My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
    Good evening madam
    It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
    good luck
    Kolbrun
    Feb 26, 2012 | Husqvarna Huskylock Computerized 936
    Husqvarna 3610 doesn't pick up lower thread
    Hi, Check to see if needle is bent. If the needle is bent it will not work well and soon it will break.
    Replace the needle. Also lube the moving parts on your machine. (fine oil) sold in most sewing centers.
    Jul 24, 2011 | Husqvarna Viking 1
    Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
    Change needle
    Clean under needle plate where feed dogs are for lint
    Clean bobbin area for lint or loose threads
    Rethread machine top thread make sure to get every thread guide
    & bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
    Check tension 3 or 4 is usually good
    after you try all this & it keeps jamming then it may need to be serviced
    Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
    I need a sewing guide, basic , starting with threading
    Hi! You can find manuals for Husqvarna Viking sewing machines at http://sewingpartsonline.com/viking-sewing-machine-instruction-manuals.aspx. Another place to look for an instruction manual for your machine is http://www.sewconsult.com/husqvarna/husqvarna_instruction_manuals.htm. I didn't find anything about replacement instruction manuals on Husqvarna Viking's website--BUT they have a neat feature called The Sewing Room that offers how-to-sew instructions. (http://www.husqvarnaviking.com/us/3368.htm)
    You can also take a look at my Hints and Tips about threading your machine.
    Let me know if this helps!
    Happy Sewing!
    Feb 12, 2010 | Husqvarna Viking 1
    Viking Designer 1 balleds / Birdnest / issues after repaired from Husk service center in midwest - replaced thread needle and adjusted tension .. freequilting and embroidery situations
    birdsnest refers to a mess of thread on the underside of fabric when you start sewing (after a few stitches all looks good). if this is the case and it is happening during embroidery, switch off jump stitch thread cutting.
    if it happens at the start of normal sewing, either hold your needle thread when you start sewing or make sure the needle thread is under the presser foot and held by the presser foot when you start sewing. this way you will have an inch or so of thread on top of your fabric which you can trim instead of a mess underneath.
    if there is a mess underneath for more than first few stitches, either your check spring in the needle tension area is set incorrectly, or your needle tension is set too loose (adjustable in sevice menu by tech only) or there is foreign matter caught in tension assembly preventing proper tension.
    scott
    Jul 26, 2009 | Husqvarna Sewing Machines
    Thread keeps wrapping around bobbin
    frustrating huh?  it happens!  even to us that have been sewing for 50+ years, but the solution is very simple.  Top thread tension is the culprit.  pull the spool all the way off and rethread the top, follow the threading path precisely and make sure the thread goes down into the tension discs.
    one more thing - when that happens often times the piece has to be removed from the machine by cutting those annoying loops on the bottom.  if this is the case, make sure you have removed all the thread clippings from in and around the bobbin case.  sometimes one little piece of thread will make you want to use swear words.
    good luck and happy stitching.
    Jan 17, 2009 | Husqvarna Viking 1
    Sewing Machines Logo
    47 people viewed this question
    Top Husqvarna Sewing Machines Experts
    Douglas Plant
    Douglas Plant
    Tally Girl
    Tally Girl
    Wayne Fellows
    Wayne Fellows
    Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
