Question about Microsoft Office Professional 2007 Full Version for PC
I can not type any type of documents, tells me its locked, how do i unlock it
  • 39 Answers
It looks like a free trial version of Microsoft Office is installed on your machine. It is good for 25 uses or for 60 days. At the end of that time it stops letting you edit your files or create new ones. You have to purchase the full version of Microsoft Office to do that.
Posted on Feb 24, 2014
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Unlock the Caps on Computers
The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files.
This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words.
When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function.
Open a word processing program.
Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document.
If lower case letters appear in the document, Caps are successfully unlocked.
Proceed if the text is in All-Caps.
Hold down "Shift" on the keyboard. Press the letter "P."
A lower case "p" appears in the document. Release the "Shift" button.
Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T."
Press "Enter" on the keyboard.
The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off.
Restart the computer to save the setting.
Enable the Caps Lock Key
The "Caps Lock" key is loved by some and disliked by others.
The key turns all letters into capitals as you type.
While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized.
The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock."
If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key.
If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels.
Updating the registry for the keyboard will enable the "Caps Lock" key.
Open the Notepad program.
Type the following:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout]
"Scancode Map"=-
Select "Save As" from the "File" drop down menu.
Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window.
Type "enable.reg" without quotes in the "File name:" field and click "Save."
Minimize all open windows to view the desktop.
Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning.
Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
Manually Update the Registry
Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor.
Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings.
Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion.
Disable the Caps Lock Key in Windows
Your computer's Caps Lock key has likely only collected dust since you first brought the machine home.
The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often.
Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key.
Download the registry file necessary to disable your Caps Lock key.
You have the option to disable your Caps Lock key or change the key to a number of different keystrokes.
For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key.
Double-click the registry file you have downloaded.
A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry.
Select "Yes" to install the registry file.
Restart your computer, once again, to complete the registry change.
Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer
The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately.
When this mistake occurs, usually you must correct some text errors and your time is wasted.
If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key.
Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window.
Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control".
Double click on "Keyboard Layout" to open the folder.
Open the "Edit" menu and choose "New" then "Binary Value".
A new file will appear on the right side of your screen with the file name highlighted.
Type "Scancode Map" for the new file name.
Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button.
Close the "Registry Editor" by selecting "Exit" from the "File" menu.
Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Hope this helps
Nov 05, 2012 | Computers & Internet
Looking to unlocking code
Hi can you please tell your mobile model and the type of lock in your mobile .If it is security lock then unlock it using default security codes .If it is network lock then codes are the simplest way to unlock it .to purchase codes visit classicunlocking.com here they provide unlock codes for all GSM mobile models.
Aug 04, 2012 | Cell Phones
My word document has locked n I have forgotton the password
You can try Word Password Recovery 5.0 to unlock your password-protected word document , This site provides several tool not only to recover your lost word passwords but your windows,excel,pdf,rar,zip .etc: http://www.recoverlostpassword.com
May 03, 2010 | Microsoft Office Professional 2007 Full...
How do i unlock microsoft word and edit a saved document?
Unlock Word document with Word password recovery tool is a good choice.
For example, Word Password Genius recover Word password and Word Password Remover remove Word password.
1. The first tool gets back your forgotten password. And then you can type password to open and edit document.
2. The second tool directly remove document password. When you want to edit Word file, just open it without entering password.
Nov 15, 2009 | Microsoft Office Professional 2007 Full...
My microsoft word 2007 document is locked, how do I unlock it?
Some authors (for example, of forms to be filled out) "lock" their documents under Windows. This is incredibly annoying, as it prevents you from fixing errors or adding anything (e.g., addenda) to the document.
If you web-search on "unlock word document," you get a bunch of pages with advice that doesn't work under Windows XP. (I know, as I've tried them all.) Here is a method that actually works.
chenk this out : word password recovery 5.0
Oct 01, 2009 | Microsoft Office Professional 2007 Full...
Microsof word is locked.
that is: word password recovery 5.0, a simple tool to unlock word document within a few minutes.
Jul 15, 2009 | Computers & Internet
Updated software, now unit tells me im missing software.
You need the unlock codes from your account at Garmin....
Go to your account at garmin that you created to manage your maps.
Click myMaps
Click Manage Maps
You should see your unit and it’s unlock codes
Copy all the unlock codes for your device
Close your internet browser
Right click on your desktop
Click new, and then click a new Text Document
Click on the newly created Text Document icon from the desktop
Type your unlock codes into the document
Click File and Save as
Change the file name to gmapprom.unl
(( important double check this please ))
Change the “Save as type” to "All files"
Close the document
You should see the file gmapprom.unl on your desktop
Right click on the gmapprom.unl file and then click copy
Plug your Garmin device in and then click Computer/ My Computer
Click on the nüvi drive
Right click on the Garmin folder and click paste
Safely disconnect your Garmin device from the computer
Regards
Richard.
May 18, 2009 | Garmin GPS
My Keyboard won't type on Word program.
It seems like your trying to type into a locked document, which means that your keyboard is working, its not the issue, the issue is the spesific file which is locked, try another document / file or turn off the lock from office settings if you can find it.
Apr 03, 2009 | Microsoft Natural Ergonomic 4000
I can not type anything in MS word 07. I have the full version. The windows says "This modification is not allowed because the selection is locked." ANyone can help? Please...with million thanks.
This is an error that happens when you try to modify or use a document that is locked.
1. Open the document
2. Select the Devloper tab
3. Click on "Protect Document"
4. On the Restrict Formatting and Editing Task Pane on the right side of your screen, Click on "Stop Protection" on the bottom of the task pane
5. If there is no password, you can start using the document
Mar 28, 2009 | Microsoft Office Professional 2007 Full...
Microsoft Office Professional 2007 Full Version for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
