Question about Exercise & Fitness
How to use this
It's easy to peddle but can't make it go harder to peddle it's to easy.
    New Friend:
    Problem Solver:
  • 12 Answers
This looks like a answering machine
Posted on Nov 09, 2014
There is a running pump sound when I put on brakes and sometimes when I don't hit brakes and a grind sound
Shelly, in most cases, these can be cured by replacing your brake pads/shoes. However, you stated that you are hearing a "pump" sound when you depress the brake peddle. So this is telling me that you may have either a vacuum issue, or having an issue with your "Brake Booster". That also runs off a vacuum. A little info for you. ^^ When your engine is running, the entire system is put under a negative vacuum. This controls things like cruise control, and vacuum assisted brakes. Older vehicle did NOT have a vacuum assist, and were called "Manuel Brake" systems. While these were more reliable, the were harder to push the peddle until the brakes worked. As an example, with your car turned off, depress your brake peddle about 3 times and then try to press it as if you were stopping. You will find that the peddle is much harder to press than if the engine were running under the vacuum. The reason I asked that you depress the peddle 3 times, is when the engine is off, you are no longer building pressure, so this pressure is naturally bled off when you use the brakes. If this does not happen, and your brakes are always hard to depress, then for sure your having a problem with your brake booster. I hope this helps, and good luck. ^^
Mar 09, 2016 | Cars & Trucks
Acceleration
pump harder n the peddles
Aug 11, 2014 | Cars & Trucks
I have a 2000 Dodge Durango and after bleeding the brakes (after doing some brake work) we can't seem to get the peddle to stay hard. When taking it out for a drive the first time you press on the...
Bleed them again, and don't leave the bleeder open, every time the person lets up on the pedal. close on the way down and open and close next time etc. Your letting air back into the system. Don't let the master run dry.
Sep 19, 2010 | Dodge Durango Cars & Trucks
Left peddel is stripped will not stay on
If it is the peddle that is threaded and not the crank then all you need to do is replace the peddle. Take the peddle off and look at the thread both on the peddle and inside the crank. Any bike shop can look at this for you and can order you in a set of new peddles or, if the crank is to blame you can order these easy enough online.
Jun 09, 2010 | Huffy Brazen 20 Boys' Freestyle BMX...
Clutch cable just fixed and just started to stick to floor again
Check each end of the cable, there should be a clamp that holds the cable casing in place. If the
clamp became loose, when you step on the peddle
it would pull the cable and case not the clutch fork.
And the result would be, what you have now.
I hope this was of some help.
Jan 28, 2010 | 1990 Nissan Pulsar
Trani shifts hard
change trans fluid and filter
Oct 03, 2009 | 2000 Buick LeSabre
1996 merc grand marq...check engine light stays on ....and the car accelerates wothout foot on the gas peddle???
nine times out of ten your check engine light means you need a new gas cap. as for your accellerater that could be a linkage issue , if you have a broken motor mount the engine will lean against the linkage . the harder it leans the faster it goes ... the faster it goes the harder it leans
May 20, 2009 | Mercury Grand Marquis Cars & Trucks
1998 Chevy Astro, Brake seizure, tight brake peddle problems
ABS engaging possible due to faulty speed sensor.
Pull 60A ABS fuse to disable to see if the problem goes away.
May 14, 2009 | 1998 Chevrolet Astro
Gas peddle on 2000 chevy silverado will get stuck
check the accelerator .sound like it come out the holding bracket.
Apr 22, 2009 | 2000 Chevrolet Silverado
The gas peddle on my truck will get stuck after I turn it on and I havae to push harder on the peddle to get it going. Have owners experienced this problem, how can I fix it?
Clean the Throttle body intake. This is a known problem with our trucks. If you don't know what this is just google it. The butterfly valves will hang up on the black deposits and make the pedal stick at the top end. Super easy fix give it a shot. All you should need is some carb cleaner and scotchbrite pad. Cheers!
Exercise & Fitness Logo
173 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
