Question about Samsung Televison & Video
Samsung screen problem
Hi how can i replace one of the bands on top of samsung lcd tv screen
4 Suggested Answers
  • 8 Answers
SOURCE: Hi I require a replacement lcd screen for a
yes go to www.dlec.co.uk
Posted on Feb 17, 2010
  • 11800 Answers
SOURCE: We have a Samsung 46" LCD HDTV and a red vertical
If the band is there constantly and looking the same then the defect is in the LCD panel itself - the tv is gone.
Posted on Oct 10, 2010
casperaugust
  • 85 Answers
SOURCE: Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Posted on Dec 01, 2012
Samsung 41" tv has band across top 2/3 of screen . Doesn't go right across to hrs, but is approx 5" wide. Can see picture thru it, but it is much darker in this area. Help!
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 14, 2017 | Samsung Televison & Video
Samsung led tv has white band to the right of screen. what is the problem?
This could be a screen cable issue.....either the cable needs replacing or has come loose!
Dec 31, 2015 | Samsung UN55B7100 TV
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
Samsung UE46D6750WKXXU verical lines on top of the screen
hi comon fault on samsung tv its a bad connection on screen bands
Mar 16, 2014 | Televison & Video
Dec 01, 2012 | Televison & Video
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
We have a Samsung 46" LCD HDTV and a red vertical band has shown up on the right side of the TV screen. Repair or bust?
Oct 10, 2010 | Samsung 37 in. Flat-Panel LCD HDTV
Red band at top of tv
Hi,if its a an LCD RPTV it sounds like a light engine problem.Basically your tv uses 3 LCD chips that create the image .Each chip is like a tiny screen that blend together to get the colors and picture right.They are green,red and blue.When they start to fail you will start to get color discoloration or that red band you are getting.May the Lord Jesus bless you!
Oct 20, 2009 | Sony Televison & Video
Televison & Video Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
