Question about HDMX Audio HMDX Jam Plus blue
I cannot get the jam plus to change back to "line-in mode"
I paired my jam through bluetooth on my phone, then deleted the pairing in hopes that I would be able to go back to line-in mode. I have tried reset button on the bottom (hold 5seconds), and I have pressed the pause/play button along w/ the power button (hold 5seconds). Both results in the flashing blue light, the jam plus attempting to pair with a device. I have tried resetting it with it plugged into an aux cable and without, still not able to use it in line-in mode.
Hi, i have 2013 bmw x3. I had it paired to my old iPhone, just upgraded to the new iPhone 7 plus and cannot connect the Bluetooth on the car to the phone - any ideas?
1. Press and hold the button with the "speaking face"on the steering wheel, then after three seconds, turn the ignition key to position 1 and release the button after approximately 3 seconds. "BLUETOOTH PAIRING" appears on the display or monitor.
2. Press the button again for approximately 10 seconds until you hear a triple acoustic signal.
PAIRED DEVICES DELETED appears on the display.
3. To finish the deleting process, turn the ignition key to position 0.
All the phones that were originally paired are now deleted.
Try pairing the new phone again.
Feb 03, 2017 | Cell Phones
Lost pairing of iPhone 5 to Panasonic kW tg7841. iPhone will not pair.
I recommend turning the Panasonic back to pairing mode. It probably came with instructions on how to do it.
Jan 28, 2015 | Apple iPhone 5
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
Why my bluetooth suddenly not fuction?
Could be corrupted, delete the pairing profile from your phones bluetooth menu. Then remove the battery from your cellphone while it is powered on, leave the battery out for 10 seconds then put it back in and reset the phone. Consult the bluetooths manual for how to reset the device/put it back into pair mode, then search in your cells bluetooth menu and pair/connect. Then pin is usually 0000 or 1234.
Rylan
Dec 15, 2010 | LG Cell Phones
I can't pair my bluetooth up with my phone
make sure both devices are in pairing mode.
press and hold the button on the bluetooth until the light flashes blue and red.
then with you phone in pairing mode it should see the earpeice.
but the bottom line is that both devices must be in pairing mode.
there will be a default code for pairing and it is probably 0000 or 1234
Jul 19, 2009 | Motorola Mobility W375 Cellular Phone
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Blueant supertooth not pairing to samsung omnia i900
Hallo Stu,
Try following the below instructions, if you haven't already tried them..
First Time Pairing to your Bluetooth Mobile Phone
When you turn ON your Supertooth Light for the first time, it will automatically go into Pairing mode ready to be found by devices in Bluetooth searches. This will be the case until you have successfully paired a phone. If you have already paired a
phone, please go to the next section.
1. Power ON your Supertooth Light. The Bluetooth Indicator (3) will turn a blinking
red/blue, The kit is now in pairing mode.
2. Go to Point 3 in the next section, “Pairing to your Bluetooth Mobile phone”
Pair the SUPERTOOTH LIGHT to your Bluetooth mobile phone to create a “Pairing”
link, or audio connection between the two. This has to be only done once when first connecting each new phone.
1. From OFF, Press and Hold the Accept Button (1).
2. While holding the Accept Button (1), switch the kit on (Press-and-release the
Microphone Shaft (5)).
3. The Bluetooth Indicator (3) will turn a blinking red/blue, when you see
this, release the Accept Button (1). The kit is now in pairing mode.
4. While the kit is in pairing mode, access the Bluetooth menu of your phone. Turn on the Bluetooth function then execute a Bluetooth search, or discover. (See your phone’s manual for specific instructions.)
5. When the phone displays the list of Bluetooth devices, select ST LIGHT.
6. When the phone asks for the password, enter 0000 and press Ok.
7. Set the ST LIGHT as a trusted/authorized device, if this is option in your phone.
Important Note: The kit is now paired. Most phones automatically connect to the
kit after pairing. With some phones you need to connect manually after pairing.
Go back to Bluetooth > Paired devices > highlight ST LIGHT > press
Options > then press Connect.
When connected you may see the Bluetooth Symbol on your phone change
slightly, either inverting in color or changing to a headset or car symbol. The kit
is now ready to use.
Repeat steps 1 -7 above for each new phone you want to use with the
Supertooth Light.
This was copied from the user manual, which you may or may not have already.. Here's a link to a .pdf file of the manual which you can also save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Blueant Supertooth Light Bluetooth Speaker...
How can i reactivate my blueant blue tooth on my motorola ic902?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 22, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Just bought a iPhone 3G and i have a BlueAnt Supertooth light and the iPhone isn't discovering it...help?
Supertooth Light.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 15, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
HDMX Audio HMDX Jam Plus blue Logo
99 people viewed this question
Top HDMX Audio Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a HDMX Audio Medical Expert? Answer questions, earn points and help others
