Question about RCA RCU300WBL Remote Control
J&M's remote 402 nisato code - RCA RCU300WBL Remote Control
I NEED THE CODE TO AN LG LCD TV FOR THE BRIGHTSTAR BR100Z
here is a list of tv codes hope this helps
Admiral 500, 614 , 902, 615, 610, 501
Advent 911, 932, 933
Aiko 900
Akai 601, 903, 922
AOC 601, 617, 103
Apex 000, 618, 604
Audiovox 100, 901, 900, 101
Belcor 617
Bell&Howell 620, 611
Bradford 901
Brockwood 617
Broksonic 902, 614
Candle 601, 619
Celebrity 605
Changhong 618
Citizen 903, 601, 619, 900
Clairtone 103
Concerto 619
Contec 901, 103
Craig 901
Crosley 303, 301
Crown 901
Curtis Mathes 400, 301, 620, 100, 500,
903, 621, 606, 619, 611,
603, 102, 402, 401, 405
CXC 901
Daewoo 100, 617, 900, 101
Daytron 617
Dumont 700, 617
Durabrand 902, 901, 201, 614, 615, 914, 918
Dynex 614
Electroband 605, 103
Emerson 620, 902, 614, 901, 200, 201
607, 617, 615, 602, 103, 101
Envision 601
ESA 901, 201, 601, 903
Fisher 620, 801
Fujitsu 615, 300
Funai 901, 615, 201
Futuretec 901
GE 400, 202, 100, 200, 607
608, 802, 402, 401, 405
Gibralter 700, 601, 617
GoldStar 601, 607, 617, 619
Grundy 901, 615
Haier 914, 918
Hallmark 607
Harvard 901
Hitachi 606, 619, 611, 005, 916
ILO 921, 925, 609
Infinity 301
Inteq 700
Insignia 614, 303, 201,301, 909, 919, 920, 934
JBL 301, 000, 604, 618
JCB 605
JC Penny 400, 609, 202, 903, 601, 607,
608, 617, 800, 402, 405
JVC 701
KEC 901
Kenwood 601, 617
KLH 618
KTV 901, 601, 103
Konka 904, 001, 304, 002, 003
LG 619, 910, 700
Logik 611
Luxman 619
LXI 400, 301, 620, 609, 607, 402
Magnavox 301,302, 303, 601, 615, 617, 803,
905, 906, 907, 908, 909
Majestic 611
Marantz 301, 601
Matsushita 004
Megatron 607, 606
MEI 103
Memorex 620, 004, 614, 104, 607, 615, 611
MGA 104, 601, 607, 617, 500
Midland 400, 700, 202, 402
Minutz 608
Mitsubishi 500, 104, 607, 617, 601
Motorola 500, 802
MTC 903, 601, 617, 619, 103
Multitech 901
NAD 609, 607, 603
NEC 601, 617, 619
Nikko 601, 607, 900
Noshi 800
NTC 900
Olevia 923
Onwa 901
Optimus 620, 004, 603
Optonica 500, 610
Orion 902, 614, 615
Panasonic 004, 202, 802, 610
Philco 301, 614, 601, 606, 617
Philips 301,302, 303, 601, 615, 617, 803,
Pilot 601, 617
Pioneer 603, 600
Polaroid 400, 910, 913, 915, 917, 920
Portland 617, 900
Prism 202
Proscan 400, 402
Proton 607, 102
Pulsar 700, 617
Quasar 004, 202, 610, 802
RadioShack 400, 620, 610, 901, 621
607, 617, 619, 402
Realistic 620, 610, 901, 601, 607, 617,619
RCA 400, 617, 800, 612, 600
402, 403, 401, 404, 405, 623
Rhapsody 103
Roomconx 614, 615, 902, 924
Runco 700, 601, 616
Sampo 601
Samsung 903, 601, 607, 617, 619, 930
Sansui 614, 902, 615
Sanyo 620, 801, 931
Scotch 607
Scott 902, 901, 607, 617, 615
Sears 400, 301, 620, 609, 607
615, 622, 801, 201, 402
Sharp 500, 610, 501, 929
Sharp (LCD) 912, 929
Shogun 617
Signature 611
Simpson 803
Sony 605
Soundesign 901, 607, 615
Squareview 201
SSS 901, 617
Starlite 901
Supreme 605
Sylvania 301, 601, 201, 901
Symphonic 901, 201
Tandy 500
Tatung 802
Technics 004, 202
Techwood 202, 619
Teknika 301, 901, 104, 605, 617
615, 619, 611, 900
TMK 607, 619, 602
Toshiba 620, 609, 903, 613
Trutech 101
Victor 701
Vidtech 607, 617
Vizio 927
Wards 301, 610, 601, 607, 608
617, 615, 619, 611
Westinghouse 926, 928
White Westinghouse 614, 101, 605
Yamaha 601, 617
Zenith 700, 614, 611, 900, 619
Feb 25, 2013 | Universal Remote Control Remote Control
Does anyone know the sky remote code for my goodmans GTVL19W17HDF ? please
Hello
Setup codes for Goodmans TV with Sky remote are:
065 064 100 588 285 037 292 544 207 318 363 399 402 515 527 392 371 245 563 297 584 060 103 263 508 063 616 055
527
055
402
563
662
696
652
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Aug 25, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hi. I need goodman tv codes on asda urc20 d1f universal remote as I have lost the manual... Any help please?
IIf all you need is the code to put in your remote, the codes for Goodman TVs are as follows:
065, 064, 100, 285, 037, 292, 544, 207, 318, 363, 399, 402, 515, 527, 392, 402, 371, 245, 563, 399
Mar 14, 2011 | Televison & Video
Requiero el codigo para programar un TV Home Electronics HTV 2929SF, el control es un J&M Electronics R-402. Espero sus comentarios.
En el buscador "Google" escribe ( J&M Electronics R-402 TV Codes) y de seguro encontraras el que necesitas.
Dec 01, 2010 | RCA RCU404 Remote Control
I need codes for tv for philips universal remote
Here are codes for Universal Philips Remotes for Televisions. Directions at the bottom to enter codes.. Good Luck!
ABEX ................................. 120
ADMIRAL ................. 701 918
ADVENTURA .................. 019
AIKO ................................. 407
ALLERON ........................ 206
AMARK............................. 603
AMTRON.......................... 906
AKAI ................................. 801
AMSTRAD ........................ 520
ANAM NATIONAL .104 805 901 906 920
AOC ............ 002 003 102 119 217 302 502 814
ARCHER ........................... 603
AUDIOVOX ...................... 906
BANG & OLUFSEN ......... 620
BELCOR ............................ 002
BELL & HOWELL .......... 506 601 701
BRADFORD ...................... 906
BROKSONIC .............. 215 316
BROKWOOD.................... 002
CANDLE .... 002 019 402 502
CAPEHART ...................... 119
CELEBRITY ..................... 801
CENTURION.................... 502
CETRONIC ....................... 805
CITIZEN .... 002 112 402 407 502 512 701 805 906 319
CLAIRTONE .................... 003
CLASSIC ............................ 805
CLP .................................... 016
CLP CLASSIC .... 013 012 001
COLORTYME ... 002 502 602
CONCERTO ............... 002 502
CONCIERGE ..................... 713
CONTEC/CONY .......003 802 805 902 906
CRAIG.........................805 906
CROWN......................805 906
CURTIS MATHES ............ 002 103 112 502 506 512 601 701 704
CXC ............................. 805 906
DAEWOO .. 002 102 110 214 303 311 314 403 407 502 503 611 805 809 909
DAYTRON................. 002 502
DIMENSIA ................. 601 704
DUMONT .................. 002 713
DYNASTY ........................ 805
ELEKTRA ........................ 701
ELECTROBAND ...... 003 801
ELECTROHOME ..... 002 502 803 901 914
EMERSON . 002 003 004 005 104 105 106 115 204 205 206 213 304 305 316 319 405 502 505 506 519 604 605 705 804 805 903 904 905 906
ENVISION ..................002 502
FISHER ....... 506 606 619 902
FUJITSU ............................ 206
FUNAI ................ 206 805 906
FUTURETEC ............805 906
GE ........ 002 006 007 018 107 114 310 312 502 601 704 719 803 806 810 901 911
GIBRALTER .............. 002 713
GOLDSTAR 002 102 117 207 217 307 502 818 914
GRUNDY ....................206 906
HALLMARK .............002 502
HARVARD ......................... 906
HITACHI .... 002 016 116 216 315 502 507 515 519 607 615 701 707 715 815 902 915
IMA .................................... 906
INFINITY ......................... 807
INTEQ ............................... 713
JANEIL .............................. 019
JBL ..................................... 807
JCB ..................................... 801
JC PENNY ......... 002 007 102 107 112 310 312 402 502 512 601 704 719 803 806 818 907
JENSEN ......................002 502
JVC ...................... 007 107 108 308 510 607 902
KAWASHO ......... 002 502 801
KAYPANI .......................... 119
KEC .................................... 805
KENWOOD ....... 002 502 914
KLOSS NOVABEAM ....... 019 408 508
KONKA .............. 203 208 219 306 317 417
KTV .................... 003 213 319 608 703 805 906
LODGENET .............. 601 701
LOEWE ............................. 807
LOGIK ........................601 701
LUXMAN...................002 502
LXI .............. 002 312 502 506 512 601 704 719 807
MAGNAVOX ..... 002 009 109 118 209 309 402 408
502 508 510 807 914 917
MAJESTIC ................. 601 701
MARANTZ ........ 002 502 807
MATSUI ............................ 807
MEGATRON ...... 002 502 507
MEI .................................... 003
MEMOREX 002 115 206 502 506 601 701 706
MGA.................... 002 102 206 502 619 803 914
MIDLAND ......... 007 107 312 713 719 818
MINUTZ ........................... 806
MITSUBISHI .............002 102 206 502 510 619 709 803 814 914
MONTGOMERY WARD 601 701
MOTOROLA .............901 918
MTC.................... 002 003 102 112 502 512
MULTITECH ................... 906
MULTIVISION ................. 010
NAD ............ 002 120 502 512
NEC ............. 002 102 110 111 502 510 602 901
NIKEI ................................ 805
NIKKO ............... 002 407 502
NTC ................................... 407
ONKING ............................ 805
ONWA ........................ 805 906
OPTIMUS .................. 120 618
OPTONICA ............... 111 918
ORION ................ 105 115 713
PANASONIC ...... 007 107 516 608 618 718 807 901
PHILCO ...... 002 009 102 109 309 402 408 502 508 807 901 914
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
PILOT .............................. 002
PIONEER ...................002 120 502 519 610
PORTLAND.................002 102 407 502
PRECISION ....................... 218
PRICE CLUB .................... 112
PRISM ................................ 107
PROSCAN ......... 312 601 704 719
PROTON .................... 002 119 220 502 910
PULSAR ............................ 713
PULSER ............................. 002
QUASAR .... 007 107 516 608 618 718 807 901
RADIO SHACK/REALISTIC ......... 002 111 117 406 502 506 601 618 704 705 805 818 906 914
RCA ..... 002 011 102 211 302 312 318 320 406 409 411
420 502 511 514 519 601 702 711 719 809 811 901 909 911 912 914
RHAPSODY ..................... 003
RUNCO .............................. 713
SAMPO ....... 002 119 502 818
SAMSUNG .. 002 012 102 103 112 212 502 512 818 914
SAMSUX ........................... 502
SANSUI ....................... 115 215
SANYO ............002 412 506 619 902
SCOTCH ..................... 002 502
SCOTT ............... 002 004 105 206 502 805 906
SEARS ............... 002 112 206 312 502 506 512 520 601 612 619 704 719 902 914
SHARP 002 013 014 111 502 712 812 813 913 918
SHOGUN ........................... 002
SIGNATURE ...... 601 701 903
SIMPSON .......................... 402
SONIC ................................ 003
SONY .................. 202 708 801
SOUNDESIGN ... 002 206 402 502 805 906
SPECTRAVISION ............ 921
SQUAREVIEW ................. 520
SSS ....................... 002 805 906
STARLITE ........................ 906
SUPREMACY ................... 019
SUPREME ......................... 801
SYLVANIA . 002 009 109 209 309 402 408 502 508 717 807 914 917
SYMPHONIC..... 520 904 906
TANDY ............................. 918
TATUNG ........................... 901
TECHNICS ................. 007 107
TECHWOOD.............002 007 107 502
TEKNIKA .. 002 019 102 112 206 209 402 407 502 512 601 618 701 805 902 906
TELECAPTION .............. 313
TELERENT ............... 601 701
TERA .......................... 002 220
TMK ........................... 002 502
TOSHIBA ... 112 313 413 506 510 512 613 902
UNIVERSAL .............. 310 806
VICTOR ............................. 607
VIDTECH........... 002 102 502
VIKING .............................. 019
WARDS ....... 002 004 009 102 109 111 206 209 310
408 502 508 513 601 701 704 806 807 914
WHITE WESTINGHOUSE ... 311 611
YAMAHA... 002 102 502 914
YUPITERU....................... 805
ZENITH ............. 002 008 115 215 405 407 601 701 713 903 916
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Nov 18, 2010 | Philips Televison & Video
I dont have the manuals to my philips universal remote so i need to add componts dvd
Try this link, http://www.universal-remote.net/philipsmagnavox.html
or instructions are as follows - Direct Philips Magnavox Universal Remote Code Entry PM335
DVD, etc.).
brand.
TV
Jul 03, 2010 | Philips Televison & Video
Help, i need to re insert the codes for a goodmans k2110pf unto a universal remote control, made by pro team but i have not got the codes anymore. can anyone help?
Ok - thanks..
The Goodmans TV remote codes are as follows ---
Have a good day..
Sep 23, 2009 | Televison & Video
I need codes For my Remote Control
These are the codes I have located for your universal remote (philips) I sure hope this is of some help.
May 11, 2009 | Televison & Video
RCA RCU300WBL Remote Control Logo
50 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
