Question about Maytag PTB2154G Top Freezer Refrigerator
Freezer freeze drys food
It seems to build up frost on meats and frozen fruits
  • 22 Answers
SOURCE: Refrig not cooling Freezer has frost build up on coils
Frost on the coils won't allow air to pass to the fresh food section, thus resulting in insufficient cooling. To eliminate this problem, you will have to get a new adaptive defrost timer ( small board ), and a defrost heater assembly.
Posted on May 04, 2009
  • 103 Answers
SOURCE: my ice cream won't stay frozen in my freezer.
Hi: Meat and other frozen foods will be rock solid at 32degrees. Ice cream will be soft it needs 0degrees to be hard. It sounds like your freezer is above 0 degrees. You tried the adjustments. Make sure the coils on the bottom are clean. They will warm a ref if they are dirty. A coil brush from the hardware store or a air compressor (plan on dusting the house when done. Just vaccuuming the front isn't enough. That's an older model but one of the controls affects both the freezer and fresh food. When it's running turn one down; if it turns off the compressor it affects both. The other control is just an air balance, to direct how much air gets to each compartment. I hope this helps, Jeff
Posted on Jun 01, 2009
  • 31 Answers
SOURCE: food in freezer covered in ice particles
The only way frost can form on the outside of your frozen foods is from moisture in the air entering the freezer. This happens when the door is opened exessively or your door seal is not seated firmly to the frame when the door is closed.
Fuji
Posted on Aug 07, 2009
SOURCE: freezer all frosted
i have the same problem and the maytag repair man said 99% of the time its the auto defrost board. i ordered one from ebay for 32.02 and will let you know if it works when it gets here.
Posted on Jul 26, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag Plus side by side (Model MSD2356AEA)not cooling in
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhkgjd
Posted on Sep 29, 2010
Model EEV-163F Whirlpool Upright Freezer. Defrosted this week, already seeing ice buildup. Freezer is cold and appears to run fine, but frost buildup seems excessive this quickly. Frost throughout
This freezer is not frost free. Being an upright limiting the amount and frequency of opening the door will reduce the build up of ice. Ice is expected and depending on humidity and quality of seal around door affects the amount of ice.
Using a thin ribbon check the seal integrity around the door. Confirm nothing is prohibiting the full closure of the door.
Adjust door if necessary. Replace seal if defective. Freeze open unsealed items in a frost free freezer before locating frozen food in this unit.
These units are likely located in the garage where the humidity is high. If used only as needed planning transfer between this and the kitchen unit frost can be minimized.
Being a conventional freezer not frost free freezer burn is less likely and frozen food will not dry out as quickly. Confirm that the freezer maintains about 0 degree F.
This unit is likely more efficient and will maintain the food frozen longer in the event of power outage.
Hope this helps?
Jun 24, 2017 | Whirlpool Refrigerators
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
What causes food to freeze in the bottom of the refrigerator & meat & cheese tray
See if there is a temperature setting on the side of the drawer. Mine has a small lever that opens a hole to the freezer to keep that drawer colder. If it's opened too far the food will freeze.
Jul 26, 2014 | Jenn-Air Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
My freezer does not seem to be freezing properly. Some of the meat is staying frozen while some is getting soft. All my bread products are not freezing at all they are staying cold but soft???
THE RED WARNING LIGHT KEEPS COMING ON AND I HAVE TO KEEP PRESSING THE FAST FREEZE BUTTON, THIS IS EVERY FEW DAYS. IF I DONT NOTICE ALL THE FOOD DEFROSTS!
Mar 23, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Temp Alarm going off, when freezer seems to be cooling fine.
You need to check the temp in the freezer to make sure it's down to around 10 degrees. The alarm will go off much above that.
Jul 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice builds up inside packages in freezer.
This is the moisture coming out of the food. It is what causes freezer burn.
The problem is made worse in frost free models by the defrost cylce. Best way to slow it down is to use vacuum bags or freezer bags. Also above 0 F food deterioates faster and below it gets freezer burn and the moisture problem faster.
Mar 22, 2009 | Frigidaire 9 cu. ft. / 255 liter Chest...
Meat freezer burns
Hi,tomonbow
ngafm at your service,
You said,you are getting freezer burn in only two days, right?
Are you putting the meat in proper freezer bags and squeezing
air out as you zip lock the bag?
If you do not use proper freezer bags you will always get freezer burn on meats!
WAIT ! This will not happen in two days!
Seems to me something else has happened to your meat prior to your purchase and it probably is not the freezer at fault.
If it happens to meat that you feel was not frozen when you bought it, check with the store of purchase to see if it came into them frozen before it was put in their refrigerator case!
Most super markets receive cases of frozen meat and then put them in the walk in refrigerator, or refrigerator case to present them for sale to the customers and they defrost in the case.
Then we think we are buying meat that is fresh and never been frozen!
Fresh meat will not freezer burn in 2 days unless it has happened previously to the time you bought it.
Also when you freeze any meat you buy, repack it in proper freezer bags and not just any zip lock bag!
But I believe it happened before you bought it.
And i'll bet it all came from the same store.
that's why some people shop at a butcher shop or Costco type store where the meat is fresher and sells out faster!
Bless you.
ngafm
Please give me a good rating before you sign off.
Thank You.
Let me know the verdict. I think I'm right on target!
Do some investigating and ask the store some hard questions!
Sep 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Jun 14, 2008 | Freezers
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Maytag PTB2154G Top Freezer Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
