Question about Orion STV2763 27" TV
Need manufacturers codes to program universal remote. see model number box 2 also see box 3 ( add more details).
Actually its 2 problems I can't get the Wii to work with the television set. Orion model tvd2710 setup menu ask if input is ANT/CABLE which one do I choose. The Wii's AV multi out plug is attached to television by 3 wire RCA consisting of a yellow for video, a white for left audio in, and red for right audio in. The kids are getting very restless with no Wii working. Please help.
2 Suggested Answers
DerStrom
  • 103 Answers
SOURCE: Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Posted on Apr 06, 2010
I have lost my sdtv magnavox tuner box remote and I have a sony universal remote control how do you program the box to the remote control?
Find the owner's manual for the universal remote (you may have to get the pdf version online) and look up the model number for the tuner in the list of supported devices. The manual will have instructions for entering the code for that model number into the remote.
Jun 25, 2015 | Sony Televison & Video
Need to program a ge universal remote to operate a magnavox sdtv box model #tb110mw9 please get. The codes
There is no setup codes for magnavox SDTV box with this remote cotnrol. If you wish to get setup codes and other details to your SDTV box, check this link. There are setup codes to other brands of remote controls, by which you can select one, which have setup codes to your device.
Feb 12, 2013 | Televison & Video
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
Dec 15, 2012 | Toshiba 32A33 32" TV
Cant find the right code for my universal remote. i own rca 40'' flat hdtv lost original remote and need the tv code to program universal remote
1. You always need to include ALL model numbers with your problem description, otherwise no one can help you effectively. 2. There is no such thing as a 'universal remote' since the coding is totally non-standard and may differ from one model to the next even within one manufacturer's current lineup. 3. You may be able to find a listing of models for a given remote here:
Remotes
When thinking about buying a 'universal' remote, get the model number and check the maker's website for a listing of models the remote can control. Finally, if the remote is older than the set you want to control, it probably won't have the necessary codes to control all of the device's functions if any at all.
Feb 13, 2011 | Televison & Video
I need the vimax TV remote control codes to program into the universal remote.
I too had this same problem and it was extremely frustrating finding a universal remote code to operate this tv. I had got the tv as part of a promotional offer through the Brick. To be clear it's a Vimax SPH4219P model. I have the perfect solution to anyone with a similar problem. The solution is the Logitech Harmony 300 universal remote. I purchased it at Walmart for $30. This remote is amazing. All I had to do was plug the remote into my computers USB port with the provided cable, then download the software. It simply asked me for the manufactures name and model number. The software found an exact match and programmed the remote itself. No frustration and hassles. Simple and easy to use, you can also add all your home entertainment equipment in the same manner. Codes are constantly being updated and added, so if you have a name brand or obscure device such as Vimax this remote is the solution!!
Aug 11, 2010 | Televison & Video
Need to find the code for citizen tv to programe a remote control
There is no standardized code for your TV; the code will differ from one 'universal' remote to another.
I suggest you write down the make and model numbers from several different remotes that seem to meet your needs, then go to the manufacturer's website to see if your TV (and other devices you wish to control) are contained in the remote's code set.
You can also go to:
Remotes
Enter your brand and model number in the search boxes and a list will appear with original and/or compatible 'universal' remotes. Often, the so-called universal remotes will not give you all the functions offered by the original.
Jun 20, 2010 | Televison & Video
Need coades for memorex
It depends on what remote you are trying to program to the Memorex MVR4040 VCR.
Almost every remote control2_bing.gif that is used today can be found at:
http://www.remotecentral.com/search.htm
Enter the model number of the remote you need codes for in; 2.Search For Downloadable Files.
Once you see the remote you are using click on View Details, click on Download File.
Find the code for your device and program the universal remote control as indicated by the manufacturer.
Feb 09, 2010 | Memorex MVR4040 VCR
Whats the code for the sungale dvd2028
It depends on what remote you are trying to program to the Sungale DVD2028.
Almost every remote control that is used today can be found at:
Feb 09, 2010 | Sungale DVD-2026 DVD Player
Programming
try this website and remember to also check codes of who actually manufactured your particular satelite box( it might be listed on the bottom or back of your satelite box).
http://www.universal-remote.net/philipsmagnavox.html
Jan 02, 2008 | Philips Magnavox Learning Universal Remote
Orion STV2763 27" TV Logo
26 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
