Question about Shark Vacuums
Just bought a shark vac or steam MV3010 40 . it was a display so it didn't come with manuiel or parts . need to find out what's missing
  • Shark Master
  • 18,391 Answers
satch498
SOURCE: shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Posted on Jun 30, 2009
SOURCE: shark steam mop model 3101
Here is the webite to purchase the carpet attachment for your steam mop.
http://www.fixya.com/support/t704954-shark_steam_mop_model_3101
Before you buy the carpet attachment, you might want to read this review. I found it very helpful because I couldn't find much on how it works on your carpet or any reviews on the attachment. Her comments were all positive.
here is the link:
http://www.epinions.com/content_425654455940
Posted on Sep 17, 2008
SOURCE: Euro-pro shark steam cleanercs618hd
I am looking for an operator's manual for the Euro-Pro Schar SC-505 Handheld Steam Cleaner.
Any ideas?
Posted on Oct 10, 2008
VacuumRepair
  • 438 Answers
SOURCE: hoover steam vac all terrain turbine gear assembly
I'd be happy to walk you through this repair. Unfortunately this is a very common problem with the Hoover SteamVacs.
Here's what you'll need to complete this repair:
- Hoover Turbine Assembly For Model F5866-900 Part # 43191001 or 90001354
- Phillips Head Screwdriver
- Flat Head Screwdriver
Step 1. Remove both the clean solution, and the dirty solution tanks from the machine, and press the handle release pedal so that the handle is laying down flat:
Step 2. With a flat head screwdriver, pry off the rotating brush speed indicator knob:
Step 3. Unscrew the silver screw that's at the very top of the see thru suction port where the dirty solution tank rests.
Step 4. Turn the SteamVac upside down so that the brushes are facing upwards. There are four clips that hold these brushes in place. You'll need to remove the brushes from the machine by squeezing the four tabs while pulling upwards at the same time. The picture actually only shows the two tabs on the right hand side being squeezed, but the tabs on the left hand side are in the exact same location:
Step 5. Once you've removed the brush block from the machine, there are 4 screws on the bottom that need to be removed. Keep the two silver screws on the very corner in place, you won't need to remove these. Remove the four screws that I've highlighted in red:
Step 6. Turn the machine back over right side up, so that the brushes are on the bottom. There are two clips that hold the top housing in place. Insert your flat head screwdriver in between the top and lower housing in the rear of the machine close to the rear wheels, and pry upwards to unclip these clips on both the left and right sides, then remove the top motor housing from the machine.
Step 7. You'll now have complete access to the turbine. Remove the two silver screws in the front of the unit that hold the turbine in place, as well as remove the front hose from the turbine:
Step 8. Once you have removed the two screws you'll be able to lift the turbine up. There's a second hose in the rear of the turbine that you'll also need to remove before you can remove the turbine completely. After you've removed the hose, take the turbine out of the machine. You'll notice to the immediate left of the turbine other hoses that connect to a black circular part. This is actually the pump that sprays the water on the floor. If you ever have the problem where the clean water solution will not spray, it's a good possibility that this part needs to be replaced.
Simply install the new turbine, reattached the hoses and two front screws. When you're putting the top motor housing back on the unit, make sure that the brush speed selector knob that's on the right side of the turbine fits through the **** in the top motor housing. Also before tighting the two screws that that hold the top housing in in front of the brushes, there's two clips. You'll need to snap the top motor housing behind these two clips. Simply push front of the motor housing until you hear it snap into place.
That's about it. If you have any trouble with this repair, please don't hesitate to use the Clarification request form here on Fixya. I'm always more then happy to answer any follow up questions that you might have. If this repair was helpful to you, please help other Fixya members with this same problem find my repair by rating it helpful. You can do this by clicking the 4 Thumbs up icons in the right hand corner.
Thank you very much,
Chris J.
GoVacuum
Posted on Apr 10, 2010
Testimonial: "Excellent description! Thanks for the great solution and pictures to help!!!!"
SOURCE: Need replacement thermal fuse for Shark steam
SE Fuse is a one time link. If it pops it must be replaced. Found them at Goodman thermal fuses for $1.25 ea. Not sure why it failed, unit is 6 yrs old, always used distilled water, never had a problem, it just quit. Circuit seems to be fine, will find out when part arrives.
Posted on Jun 27, 2010
I need ausers anual forthe shark vac steam unit
Hello, this is Ava with Think Crucial.
In order to get the manual for your Shark vacuum model, you would need to find the model number of your Shark vacuum. The Model Number is displayed on the product's rating label on the bottom or backside of the unit. Then you may visit this link to find the exact manual of your Shark unit.
Shark Product Manuals
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Nov 14, 2016 | Shark Vacuums
My shark vac then steam will not steam anymore and I am doing everything right. How do I fix this problem?
im not familiar with that brand but i am an electrician and vac tech. i would if i were you i would check and make sure the heating element had power at its connection. if there is power replace the heating element. plenty of online vac parts stores have schematics along with a parts list to help you locate part in vacuum.
Feb 13, 2013 | Shark MV2010 Vac-Then-Steam 2-in-1 Vacuum...
How to fix shark vac then steam that doesn't emit steam
Replacement parts can be found on amazon, take a look: Amazon com shark vac parts . Have a nice day
May 08, 2012 | Vacuums
My mop and vac will not steam
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 26, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I have a shark steam and vac and it has stopped steaming. the heater is warm so it is working but no steam??
heatman101
Feb 20, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do I fix the shark vac and steam . the steam is not working
heatman101
Feb 10, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Do you vacuum with just the plastic bottom or should something go on it. do all shark steam vacs come with a storage tray because there was none in my box
This is NOT a vac... just a mop...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Sep 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark vac is getting hot but hardlthe steam is coming out to
heatman101
mn
Aug 25, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Parts list for model: EP754 The plastic  hose connecter from hose to vac cracked i need new connector
Shark vacuums generally are not repairable - in this case, Shark doesn't sell just the part; ya gotta buy the entire power head. And it costs more than the vacuum did new.
Shark's are considered throw-aways; when they break they're done.
It'd REALLY be nice if Linens 'N Things hadda told me that BEFORE I bought the vacuum.
And by the way, LOTS of EP754s break in the same way yours did.
Jul 17, 2009 | Euro-Pro S3325 Handheld Steam Vacuum
Vacuums Logo
103 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
