Question about Royal RY7910 Upright Steam Cleaner
Wont spray water - Royal RY7910 Upright Steam Cleaner
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Bissell proheat2x 8920 wont spray water
Hey Patti, spray is important when you want to clean. Here's a link to toroubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1122
Jan 26, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray water
Here is a quick link to troubleshooting. http://www.bissell.com/FAQDetail.aspx?id=1196&cid=ccsocial
If you continue to have no spray, here's a link to locating one of our Authorized Service Centers.
http://www.bissell.com/service-centers/?cid=ccsocial
Nov 23, 2012 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Wont pump water
Take the water tank off, you should see 2 spraying nozzles. You need to get to these and clear them out with a needle or something. Did the trick for me.
Or could be the pump itself. Confirm this using the hand tool - if it sprays water then the pump is fine.
Sep 06, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
It wouldnt spray
it wont spray water but it willpick the water up
Aug 31, 2010 | Bissell 8930M Upright Steam Cleaner
Bissell ProHeat 8910 wont spray water or solution
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sgb
Mar 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Wont spray soap
Please look at my other posts for this solution
Aug 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Wont spray
did you press the trigger? If so, does it make any noise or does it not respond at all? If it does make noise, but won't spray, it could be a clog. Go to the vac shop to have it removed if you don't know how to take it apart yourself (I wouldn't risk it)
Oct 14, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Royal RY7910 Upright Steam Cleaner Logo
21 people viewed this question
Top Royal Vacuums Experts
Electroboy
Electroboy
Are you a Royal Vacuum Expert? Answer questions, earn points and help others
