Question about Honda Electrical Supplies
Honda em3500sx generator starts right up then runs for about a minute then stops.
Running clean gas, clean oil, spark is good, filters are either new or clean.
SOURCE: generator runs for a short time
does your generator have a metel tank? If it does it probley has rust in the shut off valve under the tank.
Posted on Nov 30, 2008
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
  • 583 Answers
SOURCE: Coleman Powermate 6250 stops after 5-8 minutes of running
the carby needs to be cleaned out properly the jets blown out with air.when you intendto stop useing for any length of time swich the fuel off and let itstop by running out of gas or drain the carby before storage ,as fuel evaporates and the additives dont they build upafter a while and start to block the jets make sure motor is level,oil cutoutcan be fooled if not level ,disconectwire if worried about that bing the problem
Posted on Jul 29, 2009
SOURCE: Honda E-1500 Generator misfiring after less than 10 minutes.
hi, i have a portable generator that has Nissan GX 1600 on it,who makes it? and do they have a web site?
Posted on Aug 29, 2009
  • 7 Answers
SOURCE: 2 year old honda eu1000i generator with new spark
SOUNDS LIKE TO ME YOU HAVE A PROBLEM IN THE OIL ALERT SYSTEM, IF YOU HAVE THE REPAIR MANUAL IT WILL TELL YOU HOW TO TROUBLE SHOOT IT!!!
Posted on Sep 10, 2009
Won't start. Just put in a new spark plug and fresh gas. filter is clean and so is the oil
Take it back to the dealer. These small units have a 12 volt DC
generator that is internally converted to 120 volts AC. As such
they are fairly complicated.
May 17, 2015 | Honda Eu-1000i Inverter Generator
Gas in oil
First of all check to see you have a good spark, If it is running fine under load ignition should not be an issue. If un burnt fuel or over fueling causes the oil / gas to wash down the cylinder walls. I would also perform a leakdown test not a compression test, remove the dipstick and listen for air coming out the crankcase, that will give you an idea if you ahve a ring problem. Also remove the air filter and see if you have any blow back from the carb blowing out where the choke butterfly is. If it has less than 150 hours on it, the rings may also not be seated in, try the above then run it hard on load and check it again
Dec 09, 2013 | Honda 3000 Watt Portable Generator
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
My eu 2000 watt generator (honda) starts fine, but consistently stops (like it is running out of fuel) after 10 to 30 minutes, then starts up and runs a while longer. I've taken the jet out under the...
My Honda generators have a low oil sensor that automatically shuts them down when a low oil level is detected. I keep a quart handy and top off the oil, and they start and run fine.
Dec 28, 2010 | Electrical Supplies
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Generator starts runs with a miss for a minute or 2 then dies just changed oil and plug checked gas supply was good any idea whats wrong
If you have good spark, clean air filter (replace anyways), try choking it half way or so. If it runs better, then it is running too lean, probably a clogged orifice or jet in the carb. If choking it makes it run worse, then it is likely running too rich. Could be a float problem, or metering tube that is clogged and isn't spraying.
Apr 29, 2010 | Briggs Electrical Supplies
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
Sep 07, 2009 | Master Heaters MASTER HONDA POWERED...
Electrical Supplies Logo
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
