Question about Honeywell Computers & Internet
Honeywell scanner lights up on top when button pushed but no scanner light
2 Suggested Answers
bobtheastori
SOURCE: Honeywell 18155 Air Purifier
This unit will not operate if it is plugged into a power strip - it must be plugged directly into the wall outlet. An extension cord may be used.
Posted on Sep 23, 2013
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
What software can I purchase so I may make barcodes with a Voyager Honeywell scanner.
Microsoft Excel can print bar-code labels. I did this for my office for our stock room and they work with every bar-code reader I've used so far.
Apr 22, 2011 | Honeywell MS9540 Voyager Hand Held Scanner...
Honeywell htt 011 air filter light won't go off
Thank you to MPODHOLA. After cleaning your Honeywell HHT-011, if the red light does not turn off locate the very small button under the red light. As suggested use a paperclip, hold the button for 5 seconds and this resets the system. Make sure the unit is on when you hold down the button. I tried it with the unit off and it did not work. Turned on the unit, held down the button for 5 seconds and the system reset. No more red light.
Dec 03, 2010 | Honeywell HHT-011 Air Purifier
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
The amber lights are blinking next to the printer icons and exclamation points on top of the printer. How do i get that to stop so my print job can go through?
There 3 light on the printer that able to indicate to user when problem occur.
1st button light blink rapidly = the printer may be out of paper, so load more paper and press the 1st button itself to continue. Or may be paper jam is occur, so clear the paper jam and press the 1st button light itself to continue.
If 1st button light blink slowly = mean the cartridge carriers are stuck, so raise the scanner unit and remove any object blocking the path of the cartridge carrier, make sure the cartridge are closed and installed properly, then lift the scanner unit, gently push the scanner support towards the cartridge carriers, and carefully lower the scanner unit until it is completely closed. After that press the 1st button itself to continue.
If 2nd LED light blinking = the color cartridge need to be replaced soon.
If 2nd LED light is ON = the color cartridge need to be replaced immediately.
If 3rd LED light blinking = the black cartridge need to be replaced soon.
If 3rd LED light is ON = the black cartridge need to be replaced immediately.
YBC (/\)
Aug 06, 2009 | Lexmark X2500 All-In-One Printer
Canoscan 4200f Light on No buttons working when pushed
 go in the computer software like windows photo gallery and scan an image or document.If the settings are corect as you say it should give you the option to aquire image from scanner
Oct 02, 2008 | Canon CanoScan 4200F Flatbed Scanner
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Honeywell hz-341-bl ceramic heater
take a heat gun or a blow dryer and preheat thermostat and any conductive leads.
after a few pre-heats it will get the idea!
Nov 15, 2007 | Honeywell (HZ-341BL) Ceramic Heater
The red light on the scanner seems to be on most of the time
If you are using magellan 1000i with no button, then it must be your scanner broken. But If you use a button trigger try to push it a while. The Button is on top of the scanner,with a white / light green color.
Aug 10, 2007 | PSC Magellan 1000i Barcode Scanner - P/N...
Computers & Internet Logo
Top Honeywell Computers & Internet Experts
Ron Dufek
Ron Dufek
Les Morrison
Les Morrison
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
