Question about Panasonic AG-HVX200 Mini DV Digital Camcorder
I plugged in two separate Sennheiser transmitters to the Panasonic HVX200 - one in each XLR connector. This is for Senneheiser wireless lav mics. I set both XLRs to mic and set the settings under the LCD screen to input 1 and input 2 and set both channel 1 and channel 2 on (again both under the LCD screen). I only get audio from Channel 1. But both mics are registered on Channel 1. No sound levels on Channel 2. What am I doing wrong?
    Problem Solver:
  • 15 Answers
It got disconncted
Posted on Feb 17, 2014
3 Suggested Answers
SOURCE: mic level problems
Also put the phamton switch in off . and put a dynamic mic. the setting in menu is better put in -50db and adjust the level control .
Posted on May 17, 2009
  • 9 Answers
SOURCE: Audio level Issues with Sennheiser Wireless MIcs
MAKE SURE WHAT LEVEL IS OUTPUT FROM YOUR WIRELESS, LINE LEVEL OR MIC LEVEL. SET YOUR XLR INPUT TO SAME LEVEL BEFORE YOU ADJUST YOUR RECORD LEVEL. ADJUST SWITCH ON FRONT OF CAMERA NEXT TO XLR. IF NOT SELECT AUTO LEVEL AND IF PROBLEM EXISTS STILL, TAKE IT TO SOMEONE WHO CAN MONITOR THE AUDIO ON AN OSCILLOSCOPE TO CHECK DISTORTION
Posted on Jan 22, 2010
I have an audio technica wireless mic with the 4 pin connector. We have purchased a new lavalier mic but are still having trouble with tge mic maintaining a connection. It keeps cutting in and out if you...
Mic plug has been replaced (new lav mic) so that leaves the mic jack connected to the body transmitter. Corrosion is a possibility...
Radio Shack tuner cleaner http://www.radioshack.com/product/index.jsp?productId=12784986
but I think it's something to do with the mic jack on the transmitter. Some units solder these connectors directly to the internal PC board and after a while, the solder connections break. Have a tech open it up and closely inspect the input jack's solder pads.
Jan 28, 2013 | Audio Players & Recorders
I bought a samson se50 headset microphone to go with my GTD Audio wireless system. It has the correct adapter plug to plug in to the transmitter. The plug is a mini XLR plug. The microphone does not...
You need power from the transmitter to power this mic. See your mics specs to determine if it needs "Phantom Power"
Perhaps the transmitter doesn't supply power. Condenser mics may not work. Stay with the dynamic type. IMHO
Jul 29, 2010 | Nady Systems Nady ATM-75 Headset Mic w/...
I want to wire an ECM 77 sony lav mic to an SK 100 G2 wireless pack by sennheiser. Can you send me a wiring diagram. Thanks for your time. Ray
Here is the standard wiring diagram for a mini XLR : http://www.smartwireless.co.uk/users/UserFiles/File/Pin%20wiring%20details%20for%20Smart%20beltpacks.jpg Have a look at this post:http://www.dvinfo.net/forum/all-things-audio/128889-sennheiser-sk100-jack-confusion.html If that doesn't help try this company for info by contacting them with your problem as they sell a variety of adapters:http://www.hosatech.com/contact/contact.php
Nov 26, 2009 | Cycling
How to connect lavalier mic to panasonic dvx100b
Pretty easy, connect it to the xlr connector (hope your lav do have xlr connector) then swith the external mic switch on, phantom power switch to on, and front switch to mic (not line) and ajust the level.
Sep 14, 2009 | Panasonic AG-DVX100B DV Digital Camcorder
We have a Sennheiserew100 G2 mic kit with a wireless lav mic and transmitter we use for a canon xh-a1. The shotgun mic has been prefect but the lav mic is creating a static/noise in the background but then...
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Apr 13, 2009 | Sennheiser 100/500 G2 Series Wireless...
How do I use 2 mics for the XL2 simultaneously?
Hi, on the left side of the camera you can set 'audio monitor'. Default is channel 1/2. You can choose to listen to 3/4 or 1/2 and 3/4 simultaneous.
In the menu of the cam you can set between 12 bit audio recording or 16 bit. 16 bit only records on channel 1/2 (the front mic). In 12 bit mode you can record audio on 4 channels.
hope this answers a bit of your question
Mar 17, 2009 | Canon XL2 Mini DV Digital Camcorder
Could be your capture device.  Isolate this problem by monitoring the quality of the audio at the RF reciever, then monitor it at the camera.  I'm assuming you do not have a EFP mixer or other device that will actually measure your Dbm or Vu levels - what happens if you play the tape in the camera and monitor the output of the camera with an external device - even a TV or stereo? If it sounds good on your TV turn your attention to the capture card.
Jul 05, 2008 | Panasonic AG-DVX100B DV Digital Camcorder
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic AG-HVX200 Mini DV Digital Camcorder Logo
47 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
