? I found some water in the drain hose and emptied that. With the interior lights on the freezer works better than lower box but neither is optimim
With all of the lights off, go to the back of the refrigerator. You will see a white plastic block with two wires going into it and two wires coming out. This is the 12vdc power supply. verify if you have atleast 11.5vdc (with the lights off) If you do not, then turn the lights on and see if you have voltage. If you do then you do not have dedicated 12vdc to your refrigerator which is required to power the circuit boards. The water in the condensation tube is ok. It will actually keep warm air from getting into your refrigerator and thereby raising the internal temperature.
SOURCE: RM2652 fridge works on 110 and gas but won't switch between them
Remove the upper control board panel. Use a small screw driver, open the freezer door, under the control panel you will see a slot on each side. Put the screw driver in the slot and push up. That side of the panel will pull out. Do the same on the other side. Turn the control panel over and unplug the circuit board and wait 15 seconds. Plug the board back in and give that a try. If that does not work replace the upper board. To order a board you will need Model, Serial and product # found on the inside of the fridge.
Thanks for using Fixya
Jerry
The liftgate lamps
Courtesy/map lights
You can't turn them on manually ?
This could be a BCM problem , this best left to a ASE certified repair shop or the dealer .
