Question about HP ENVY 5535 E-ALL-IN-ONE PRINTER
Black not printing properly
Brand new and it only prints a center stripe of all letters in black
geekofcomp
  • 47 Answers
SOURCE: Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Posted on Apr 12, 2008
  • 327 Answers
SOURCE: Print coming out gray even with brand new HP cartridge
either it could be set in the printer properties to print in gray scale or it could be the lens of the printer that needs replacement as if the lens go weak the prints come out very light.
Posted on Dec 15, 2008
Joed911
  • 4338 Answers
SOURCE: HP J5680 is printing and scanning vertical gray stripes
The fix is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00704831&cc=za&lc=en&dlc=en&product=3301296
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 03, 2009
  • 240 Answers
SOURCE: Normal color print ,black print cuts off top/bottom of letters
Suggest using the printer software utility to clean the print heads, then print a test page.
Posted on Nov 29, 2009
pineworks
  • 4041 Answers
SOURCE: prints fine in black; does not print colour.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 25, 2010
Black 3e Cartridge
check the printer head and roller inside the printer
also check the nozzle because it may be clogged due to some
dust
Jul 03, 2008 | Canon PIXMA MP780 All-In-One InkJet...
There is black 1" stripe down middle of page. I
The drum is defective, and leaking, Brother warranties if you are original purchaser (in canada, www.brother.ca)
Dec 10, 2010 | Brother HL-2070N Laser Printer
Have a 2 year old brother printer HL5250DN THere are black stripes on the paper while it's printing. The printing is fine just these ugly stripes on the pages. It's worse on the legal pages than it is on...
Look in the manual and operate the cleaning cycle to clean the cartridge. If this fails, the cartridge may be getting low and require changing, but striping is usually because the cleaning cycle needs to be run. Good luck
Jul 16, 2010 | Brother Office Equipment & Supplies
How do I clean the print heads? My black ink will
  1. Load unused, plain white letter or A4 sized paper into the tray.
  2. Open HP Solution Center:
    • Windows XP: Click Start , click All Programs , click HP , and then click HP Solution Center .
    • Windows Vista: Click the Windows icon, click All Programs , click HP , and then click HP Solution Center
HP Solution Center opens.
  1. Click Settings.
  2. Under Print Settings , click Printer Toolbox . The Printer Toolbox opens in a new window.
  3. Click the Device Services tab.
  4. Click Clean the Printhead .
  5. Follow the prompts on the screen, and then click Done .
May 30, 2010 | HP Photosmart C5180 All-In-One InkJet...
Zebra stripe wont print properly
Check the printhead pressure. there is an adjustment screw that does this. It could also be that your platen roller is worn or that your printhead has burned out pixels.
Dec 30, 2009 | Zebra Stripe S600 Thermal Label Printer
Colorlaser prints black badly
I had a similar problem, which I fixed by carefully wiping the drum with a soft tissue.David
Mar 16, 2009 | Samsung CLX-2160N All-In-One Printer
Stripey printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 28, 2009 | Canon BubbleJet i560 InkJet Printer
Canon MultiPASS MP700
I had the same problem. My 4 year old MultiPASS MP700 started banding magenta stripes across everything I printed.
I suspected the cyan printhead was clogged because the printhead tests showed two of the cyan columns as half missing.
Canon was less than helpful. I went off of my suspicion that I needed a new printhead. I found one from an online supplier for 50 bucks...better price than a new printer! I put the new print head in and it works like new.
http://www.precisionroller.com/print-heads-for-canon-multipass-mp700/products.html
Jan 14, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
HP ENVY 5535 E-ALL-IN-ONE PRINTER Logo
35 people viewed this question
Seeker5211
Seeker5211
