Question about Dell Computers & Internet
Unlock dell bios on dimension 9150
Can't boot...screen is black and white writng flashing asking for system password
SOURCE: floppy diskette seek failure
F2 Scroll down to "Drives" and open the menu. choose "Diskette Drive" and turn it "Off".
Posted on May 19, 2008
ehsan_bba
  • 112 Answers
SOURCE: bios problem on dell dimension e510
At first u need to remove the bios. wait for 5 minutes. then add the battery. start it
Posted on Jan 24, 2009
  • 51 Answers
SOURCE: my dell dimension 8400 bios a03 fails to bootup
You need to reset your bios settings. Open your case and remove the cmos battery for 10 minutes. Caution: unplug all ac plugs before you open your case. put the battery back in and turn it on you should see an error message saying: you need to set system time and date. If you see this then you have successfully reset your bios settings and the defaults should load up. follow the instructions to change your time and date settings and save. reboot and hopefully you can boot up. I hope this works.
Posted on Mar 10, 2009
whitebirch
  • 433 Answers
SOURCE: [Ithr]checkpoint failure dell 8400 dimension
What can cause this error?
Well, this is the problem since quite a variety of problems can trigger the error.
1: the bios can be malfunctioning (a bios reset or flash can give a solution)
2: the cpu can be malfunctioning (this requires a new cpu)
3: the cpu socket can be failing (this requires a new mb)
4: the problem can be with bad usb sockets
5: even a bad uplink to a usb hub can cause this error to appear.
Did you change your monitor lately? I would chase down the USB things first...that and the monitor seem to trip the trigger...
Hope this get you started- I think you were right on target with the flash of the BIOS-try it again using the BIOS flash downloaded from the dell site...and to run the chipset again...it just might
Good luck my friend, hope this helps, please leave rating, thank you kindly
Posted on Apr 27, 2009
  • 8 Answers
SOURCE: Can't boot up Dell 5100 Dimension, amber light flashes
When you mean the amber light, is that the blinking hard drive access light or the power light? Different cases have different colors on it. Mine has blue and green lights.
If you see the boot screen (bios) and then after it goes to boot, does it blink and hang?
This could be a simple operating system issue, hard drive or hardware/motherboard issue. If you could provide more information, that would help.
Posted on Jun 28, 2009
Cannot bypass first password
At boot hit f8 boot in safe mode and then go to control to user accounts.If you cant change your user password make a new user or use Hiren's BootCD to unlock any user passwords on that system.
http://www.hirensbootcd.org/download/
http://www.ezsystemrepairs.com/ Live Tech Here !
Nov 09, 2012 | Dell Dimension XPS 400 PC Desktop
I entered my restore disk after receiving message on hard drive on the dimension 9150. Got message
Hmmm, what concerns me is that your system BIOS is not discovering any of your SATA Drives, That sounds like an Issue in your motherboard not your OS. I would go into your BIOS settings and look for a link that says reset bios to factory defaults, then try and boot again without the recovery disk. Please keep me posted on what happened if this does not we will trouble shoot more.
Sep 03, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
It wont boot, goes to black screen with whit blinking dash
Yes, this sounds like the traditional black screen issue, but it's different! This machine is a Dell Dimension 3000 with XP. System won't boot. After Blue Dell BIOS splash screen with F2 & F12 options, it just goes black. There will ultimately be a white cursor in the upper left hand corner. I can edit BIOS with F2, I can get in to the boot menu with F12, but I can't do anything after that. I can even get in to the Safe Mode menu (F8), but it never boots.
Aug 14, 2011 | Gateway LT2001u Netbook
I want to restore my dell dimension 9150 to factory settings can u help
If you were using Windows Xp just press Ctrl + F11 when you turn on your computer.
Press F8 if you were using Windows Vista then select repair your computer from the list.
Then if you have any disk or any Operating System disk insert the disk then boot from CD and follow the on screen instructions.
Hope it helps you....:)
Sep 06, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Error when starting Dell Dimension 9150 desktop PC: X300XT BIOS P/N 113-A33437-102
go to www.dell.com and check for a bios update if one is not present contact support and tell them your problem
May 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell 8400 No Boot, not even POST
It sounds like your bios were improperly flashed or went bad. The X300 SE message is your video card. So your video card works, the system mostly works, but the BIOS isn't starting up. You should contact Dell and tell them the situation.
Apr 19, 2010 | Dell Dimension 8400 PC Desktop
System password error
This password thats its asking for is upon first boot I assume before windows even trys to load. If thats the case theres a jumper on the motherboard that lets you reset the bios/cmos killing out the password and setting it back to factory stardards. You will have to goto dell.com and hit up there support section for a manual on were exactly its located but this will fix your password issue.
Mar 19, 2009 | Dell Dimension E310 PC Desktop
Can't get pass the background screen when pc load
The sequence is:
a) The Dell bios splash screen is displayed,
b) the screen will go black,
c) the disk activity light will flash for about 5 - 7 seconds, then will remain off.
d) you force a power off,
e) wait a few seconds,
f) then turn the machine back on.
g) The bios splash screen is displayed,
h) then a black screen with white text is displayed, reporting that Windows was not shut down nicely and would I like to boot into safe mode or safe mode with networking, or others.
g1) If you choose Safe Mode, Windows will boot up successfully. If I restart, the computer will usually (probably) boot into Windows fine.
g2) If you choose Boot Normally, the computer will usually (probably) enter the black and hung state.
see if that helps and the if possible do a do a system restore to when the system was working correctly.
Aug 03, 2008 | Dell Dimension 2400 PC Desktop
Computers & Internet Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
