Question about Rival Crock Pots & Slow Cookers
Grill won't stay lit beko dg682
Grill will only stay lit if you keep the control knob pressed in. If you release the knob, the flame goes out. I suspect thermocouple, but not sure how to replace item. Any help ?
Small auxilliary burner will not stay lit, however long the knob is held in.
You need a new thermocouple which is that little post that the flame heats up when you are holding the button in. You need to get a qualified gas fitter to do this, due to the dangers of home repairs and the explosive nature of gas.
Nov 26, 2015 | Crock Pots & Slow Cookers
We have moved into a house with a Gaggenau oven EB 768- 769 and EB 738-739 and there is only the one element in the oven below - the hot air oven.Does this mean there is a missing element from the lower...
We have this oven too, and it came with one element. You can move it to the other sockets, or buy additional ones. We moved ours to the top oven, because it's nice to be able to grill while using the main oven.
Jan 29, 2011 | Crock Pots & Slow Cookers
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
I try to set the time and temp and just keeps blinking
try to push and hold after you set the time and/or temp until it flashes the appropriate setting then stays solid
if there is a menu button.... time, hour... press till the right hour is on, min.... til the right min is on then menu or ok and either release or hold....
basiclly a process of elimination.
not sure if it will solve your issue. just giving you another option to try.
also unplug and wait 10 sec to let the slow cooker reset before you try again
let me know at sparkallen@aol.com
Dec 25, 2008 | GE Crock Pots & Slow Cookers
Corningware Microwave
Preheat browning grill 5 minutes in microwave on high, then cook items.
Feb 03, 2008 | CorningWare Crock Pots & Slow Cookers
Westbend Crock Pot- temp control knob won't stay
You might consider buying a whole new base considering the problem you are having purely as a "safety issue". Temperature controls can be serious safety hazards. If it's not stable best if you replace the base. You can buy one at West Bends link for half the price of a new one. http://www.westbend.com/westbend/catalog.cfm?dest=dir&linkon=section&linkid=5 Or you can also try this first. At some time in its use you might have gotten food oil in the control. Take the knob off and spray a commerically available "electronic contact cleaner" along the shaft and into the control pot. Turn the shaft back and forth several times as you do this. Depending on how dirty it is you may have to spray it quit a bit before it is cleaned out. I don't believe the base is emmerasble in water so don't do that. ***This is only a temporary fix and not the best one. *** The time and money you will spend fixing it if you can even find the replacement part is probably more than buying a replacement base.
May 10, 2007 | West Bend 84754 4-Quart
Rival 38601 Smart Pot 6-Quart Slow Cooker can't get to to go to warm
Here is the manual for this cooker; http://www.crockpot.com/manuals/38601-C_English.pdf page E4 and E5 tells you details of programming/timer/temperature. Check through everything and see if you can figure anything out. after cooking, the unit should automatically switch to warm mode, if it isn't doing this then unfortunately i think it needs a replacement control board - probably not worth doing. If you want to give it a try then post again and we can try and source you the bits Hope this helps :)
Mar 16, 2007 | Rival 38601 Smart Pot 6-Quart
Crock Pots & Slow Cookers Logo
44 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
tsalagi152
charles
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
