Question about Fujitsu HALCYON ASU24CL1 Wall Mounted Mini Split Single Zone Air Conditioner
Fujitsu halcyon inverter do not respond to remote control
After changing batteries of the remote, the unit stopped responding to the remote.
bobotfel
  • 236 Answers
SOURCE: Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Posted on Jan 21, 2009
bobotfel
  • 236 Answers
SOURCE: A/C will not respond to remote control.
The unit has a problem with the safety device, its either defective or have some error. Try to reset the error by disconnecting the power supply for 10sec. then "on" and try. If error still exists may be some of the safety device is defective. You need a qualified technician for this problem.
Check also the air filter if clean and clean if dirty and reset the error.
Posted on Feb 13, 2009
SOURCE: Have model ASTB24LDC/AOTS24LDC Inverter Fujitsu
I have same problem like yours to my newlyinstalled Fujitsu multi-split system (the first time use since system installed1 week ago). I rang the electrician whodid the installation; he said it must be the units themselves nothing to dowith electricity. Okay, then I rang Fujitsu and their local service agent. Theysuggested me to switch off C/B for an hour to reset the units. I followed theinstruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired tothe outdoor unit). So I used a multi-meter to test the power terminals of indoorunits (Danger! If you have no idea about this, don't even try! ): it seemed nopower supply even C/B is on. I turned to the isolator which next to the outdoorunit. The isolator was making arcing noise when I switched it on and off. Theindoor units suddenly turned on for few minutes then died again. So I figuredout the problem is that crooked isolator. I called the unhappy electricianto replace the isolator. End story....
I hope my experience will give a littlehelp to you...
Posted on Nov 23, 2010
SOURCE: My Fujitsu Halcyon Split ac/heater wall unit is
hi i have fujistu inverter2500/600 and it is shut down after 3 minutes after starting up
Posted on Dec 19, 2010
Daniel S
  • 4323 Answers
SOURCE: fujitsu iaq halcyon inverter is
Hi
It is a common issue and occurs due to blockage of air filter, drain and evaporator coils. Please check that there is no blockage in the drainage of inside unit. If so, then please clean it. Also clean the air filter and evaporator coil of any lint or dust and condenser line is mounted properly. Hope this helps...please post back for further assistance.
Daniel
Posted on Jul 27, 2011
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
Why has my JMB TV stopped responding to the remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Aug 18, 2014 | Televison & Video
Philips htl2100/12 soundbar doesnt respond to remote control after plugging in
My soundbar won't power up. So I pull the battery out of remote, press a few buttons, put the battery back in and all of a sudden the device can be powered up and controlled. Until next time it stops responding. I replaced that original battery with a new one but the problem still persists.
Dec 10, 2013 | Philips SoundBar DVD Home Theater with...
Fan unit not responding to the remote to change speeds
The red light on the remote is the battery indicator light. You probably need a new capacitor. Take off switchcup & check black box to see if it is going bad.
Jul 10, 2013 | Hampton Bay 46056 Callaway II Ceiling Fan
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Hp media center pc 2002 remote stopped working. The ir lights up when any key is pressed on the remote, but computer won't respond to it. tried to roll back one day but didn't fix it. Tried to roll back...
If the menu button is on the remote and the unit is not responding to remote.....
try changing batteries and clean the remote and receiver lens.
Mar 16, 2008 | Computers & Internet
Fujitsu HALCYON ASU24CL1 Wall Mounted Mini Split Single Zone Air Conditioner Logo
158 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
