Question about Proscan 26LB30QD 26 in. LCD HDTV
Power problems Power cord does not fit properly and power turns off while in use
    Top Expert:
  • Proscan Master
  • 75,417 Answers
Replace the power cord. It can be bought separately. Contact the authorized dealer. Gopakumar Gopalan Google
Posted on Feb 17, 2014
Where is the reset button on the kirby sentra
I'm not aware of any "reset" button. If the vacuum does not turn on, it's usually due to one of the accessories not being installed properly.
From the manual:
"IF THE MOTOR DOES NOT RUN WHEN THE MOTOR ON-OFF SWITCH IS PUSHED:
1. Make sure the Power Cord is plugged into an outlet and that the outlet has power. (Check for a blown fuse, tripped circuit breaker or power company trouble.)
2. Make sure the cord plug is fully inserted into the unit.
3. Look for breaks in the Power Cord insulation. If the cord is damaged, get a new one. DO NOT ATTEMPT TO REPAIR IT. Use only a genuine Kirby® Power Cord. Do not use standard extension cords.
4. Make sure that an attachment or accessory is properly mounted on the front of the Power Plant. The unit will not run without the Power Nozzle , Hose Coupling, Air Intake Guard or Accessory Brush Nozzle in place.
5. The unit will not operate without either a Filtration Bag Assembly/ Mini Em-Tor® collector ?, Attachment Hose or Carpet Shampoo Tank properly installed on the Air Exhaust Port ?.
6. The Filtration Bag Assembly/Mini Em-Tor collector, Attachment Hose or Carpet Shampoo Tank must "click" firmly into place for the unit to operate. If the fitting is too tight and you have difficulty installing the above, apply a small drop of water to the gasket to reduce friction and ease installation.
Here's a link to the owner manual if you lost yours:
http://kirbywhq.powweb.com/manuals/se2/45B6BEDE315CBA7174350751ECA71E5D/LV-260012-E%20Domestic%20Manual.pdf
Feb 09, 2018 | Kirby Vacuums
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
I need a power adapter for telephone base for model 30524
Not a problem. Take the base unit with you to Radio Shack and they will get you a proper replacement. (The numbers on the plug in to the unit will say how many volts Direct Current are required to operate is properly and the tag underneath will also state how many milliWatts of power are required at that voltage.) The key is buying the proper plug in end that fits the socket. Radio Shack has units with several socket tips so you may select the proper one. Make sure the polarity of the socket plug you use matches the wire polarity... the stripe on one side of the power cord is the + side on the socket tip.
Apr 04, 2015 | GE 30524ee3 3 Headset Corded/2 Cordless...
Turns on then turns off
Hardware issue? Try removing the battery, power cord, hard drive and RAM then power up with the power supply cord. If you get error message and it seems stable, remove the power, fit the RAM and continue until you find the problem.
Jan 06, 2014 | Computers & Internet
I have a Bellin router and sometimes turns orange sometimes for half hour or more.What could cause this.
1).This problem may be due failure of power supply from the power card. That means power cord may not be working properly. Kindly purchase the new power cord and try to solve your problem.
OR
2).Disconnect the power supply and disconnect all other cables from the router. The switch of power supply button of router may not be working properly. Kindly try to press the power supply button and release again and again for 3 to 4 times. Then connect all the cables and power cord. The problem may be solved.
Aug 16, 2012 | Computers & Internet
Battery doesn't appear to be charging.
There may be several physical problems. You should make sure that the battery is properly plugged in and no switches that allow it to be removed are in the open position. Checking that the power cord if plugged in proper at the laptop, the power brick, and the power outlet may also solve the problem. If none of these work, try using a different power cord that fits your laptop if you can get your hands on one. You may also want to try a different power outlet, or make sure that power outlet can power another device (eg vacuum, phone) so you know if it's actually a problem with that power outlet and not your computer.
If you battery doesn't charge even with a cable that you know works for another computer, and the outlet is working properly, your battery may be corroded or suffering from over-use over a long period of time. In this case it would be best to buy a replacement battery directly from Dell which you can do here:
http://www.amazon.com/Replacement-Laptop-Battery-Studio-7200mAh/sim/B003FZ33SS/2
Mar 19, 2011 | Dell Studio 17 Laptop
Yes.. I have a LexMarkX1270 Printer and I can't get the Power button to come on. I have check the power cord and witht the USB cord and they are both connected correctly. So, can you tell me with the...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Properly secure the power cord in the power adapter. Other end should be plugged to the power outlet in the wall. Bypass any surge device or power strip as they can cause low amperage. Replug power adapter behind the printer and properly secure it. If printer won't automatically turn on, press the power button. If problem continues, it's a possible defective power adapter or a defective printer. I strongly suggest you contact Lexmark technical support to further investigate the problem.
Sep 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
Wont turn on!
Unless the power cord is loose, it sounds like the unit is defective. There are two places to check the power cord. The 'brick' has to be firmly inserted into the back of the printer and the cord has to be properly fitting into the brick. If all is well there, it sounds like something more drastic is wrong.
Steve
Feb 26, 2009 | Lexmark X2350 All-In-One InkJet Printer
TV doesn't turn on. All power sources working.
Check the main power cord for proper fit from the wall too the tv. Make sure the cord is well fitted in the outlet and the tv. If the connection is in standing and there's ac voltage coming from the outlet.......then it
may be a blown fuse or a dead power supply circuit with-in the tv. If so, the tv needs to be serviced.
Dec 24, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
Proscan 26LB30QD 26 in. LCD HDTV Logo
21 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
