Question about Toshiba SD-4000
Volume humming machine volume is messed up
It doesn't get water or turn, it just hums
Hi, I posted my question yesterday with no help. Took matters into my own hands and I ended up having one of my 5 yr olds sock stuck in the pump. It was messing up my whole washer. It wouldn't drain or spin... Nothing!!!! All is good now, I'm washing clothes as we speak :) best of luck. It was an easy fix with no out of pocket costs.
Mar 04, 2013 | Washing Machines
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
When turning up the volume speakers start to humn. Tried on all inputs still humming. Sound comes out but humming is there. Humming only stop when turning the volume all the way down.
You need to add a "ground lift" to the power cord to your system. What you're hearing is a 60 cycle hum (electricity) from house power.
Mar 11, 2011 | Philips MCD-735 System
I have a Starbucks Barista Espresso Sin 006 that I got used from someone. They hadn't used in it awhile and didn't have the manual. I'm told that before using I should Prime it. The instructions says...
Hi
Since the machine hadn't been used in a while you might have a stuck check valve in the pump. You say it hums. Does it rattle or just hum? If it hums something is stuck in the lines that is keeping the pump from moving water. If it rattles and makes a lot of noise its the pump check valve or it could be a plugged flow meter/ intake line.
Jan 16, 2011 | Starbucks Saeco Italia Digital Barista...
I have Insignia ns-p42q-10a tv, there is a loud hum when the volume is on when you mute the volume it goes away? Any suggestions?
check other inputs AVI, HDMI,,
do you here the hum on all inputs?
The hum maybe from a bad ground loop,, unplug all pluged in inputs, [dvd,games,radio,ect] <--check for hum.
If the hum is gone, plug inputs back in one at a time and test,,
When you find the source of the hum, go get a ground loop isolator to fix.
Mar 25, 2010 | Insignia NS-P42Q10A Plasma TV
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Reel to reel tape recorder hum
Try replacing the Electrolytic Capacitor(s) on the power supply. They will be big value anywhere between 2,000UF and 6800UF. But capacitors of this type are notorious for causing hum, any on the deck could do it!
Apr 05, 2009 | Audio Players & Recorders
Panasonic KXFHD331 something simple the ringer volume was adjusted and somehow it got messed up and now wont receive I dont know what to change
ringer volume can bi adjusted with volume key or with navigator kex by pressing up and down.if fax is not receiving just check fax receive mode .put iton fax only mode.by mian jee
Dec 02, 2008 | Office Equipment & Supplies
Whirlpool washer humming!
If you open the lid, does the humming stop? If so that means your lid switch is good, the hum is from you motor, which means your transmission is messed up. You need a service call.
Sgt 48
Jun 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Toshiba SD-4000 Logo
12 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
