Question about Brookstone Handle-Mount Grill Light
How do I change the bulb in the Brookstone Grill light?
Need a replacement battery cover for brookstone grill light
Fixya does not sell replacement battery covers for Brookstone grill lights.
Oct 16, 2017 | Brookstone Grilling
How do I change the light bulb on the Brookstone Daimond 367RL... how does the flush ceiling mount glass cover come off...
contact manufacturer tech support they will guide you on which light style is in your unit for removal of lens without breaking it
Jan 10, 2015 | Coachmen 2011 Brookstone 367RL
Replace the led's
LEDS have very long life. I dont believe that is the issue. Can you post the make and model and what happened?
Apr 06, 2014 | Brookstone Handle-Mount Grill Light
I can't get the cover off my grill light can you help
I had the same issue. There is a rubber O-ring that makes ti waterproof and is very tight when new. You twist counter-clockwise as per instructions and then use your thumbs from underneath the cover to pop up one side of the cover (and possibly work the other side as well) until the seal is broken. Once you open it once it gets much easier.
Dec 24, 2013 | Brookstone Handle-Mount Grill Light
How to put batterys in my grill light
I had the same issue. There is a rubber O-ring that makes it waterproof and is very tight when new. You twist counter-clockwise as per instructions and then use your thumbs from underneath the cover to pop up one side of the cover (and possibly work the other side as well) until the seal is broken. Once you open it once it gets much easier.
How do you change the batteries of the bbq grill light
The battery compartment is the opposite end of the light from the on/off buttons. Turn it counter clock wise about 1/2 turn and the batteries should push the end cap out. Remove it all the way. If the unit is new and doesn't have batteries you might have to pull the end cap to get it free of the compartment. Once the cap is free tip the batteries out, replace with new batteries, replace the cap and tighten by turning it clock wise.
Nov 05, 2013 | Brookstone Handle-Mount Grill Light
How do I put batteries in the brooks tone BBQ grill light
I had same problem. Note you cannot see down the Battery tube as there is a top attached to the battery cover that turns. I worked a very thin screwdriver head between that top and the light unit, and the cover then wiggled free rather easily.
Jan 09, 2013 | Brookstone Handle-Mount Grill Light
Brookstone grill alert manual
My grill alert will not connect to the remote prob? The prob flashes yellow? The unit is trying to connect at least but doesnt happen.
Dec 21, 2011 | Brookstone Grill Alert Talking Remote Meat...
Can't get the cover off to change the light bulb
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
May 20, 2010 | Broan-NuTone N-8663RP Combination Light...
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Brookstone Handle-Mount Grill Light Logo
190 people viewed this question
Top Brookstone Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Brookstone Grilling Expert? Answer questions, earn points and help others
