Question about SmartParts SP-DPF56E Digital Picture Frame
When i put my memory card into the card slot it always read card not ready why do they do that
The screen always put card not ready and i did check it was all in jpeg file
I have an LG TU550 , i took the memory card ouy and when i put it back in it says memory card not ready ... why .. please .?
hi katina destr Take a unused toothbrush or a can of air and clean out Then put the memory card back into the slot it should read the card now. If your your still having trouble go to your picture gallery and put your card back in. Also I want to to take the battery out and put it back in this should reset the phone. OK hope this information helps.
Dec 12, 2010 | Cell Phones
Canon PowerShot SD790 IS Digital Camera
Sounds like two things are happening here. You may be putting the card in improperly...check the manual to see if the card should be face up or face down. Also, be sure the slide switch on the side of the card is in the unlocked position.
May 14, 2010 | Canon PowerShot SD790 IS Digital Camera
Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Apr 16, 2010 | LG RUMOR Cellular Phone
My playstation keeps saying to put in a memory card.. even though I have done
did you try reading the memory card without any game discs put in via the ps2 menu?
is your memory card working properly? could be a corrupted memory card or a faulty memory card slot.
try putting a friend's memory card on that same slot.
if it works... then your memory card is gone bad...
if it doesnt work...then your memory card slot has gone bad.
else try putting your memory card in your friend's ps2, see if that ps2 reads your memory card. if it does...then your memory card slot has gone bad.
Sep 07, 2009 | Sony PlayStation 2 (PS2) Console
LOST PICTURE ON FLAT SCREEN
If you buy new PCI video card there is alway CD software attached on this,you should claim for this because it was the driver for your new video card ,without it your PC will have an abrormal operation .Are you sure it was your video card?you can consider also your memory card,Wiht out hardisk,CD room,floopy your computer will run it can open your monitor configuring the cmos and bios.Try on this one disconnect hardisk,cd room,floopy then detouched your memory card clean using pencil eraser the sloted terminal of your memory card,also your video card try to clean terminal by pencil eraser.Then put back memory and video card again if the monitor work.If ok put back again the cdroom,hardisk, and floopy.If not ok Isolate checking the memory and video card also the processor.
Mar 14, 2009 | Dell Dimension 2400 PC Desktop
PS2 8MB memory card not detected at all!
try put in another slot or blow or make shore all that silver stuff is on it
Nov 22, 2008 | Sony PlayStation 2 (PS2) Console
I put a game cube game in to the wii and it says to insert a memory card into slot A so i put a 128mb memory card into slot A andi turn the wii on and it says no memory card found in slot A WHY?
It might be talking about the GameCube memory card slots, not the SD card slots. There should be a door on the top/left side of the WII. See if it's talking abou that.
Aug 18, 2008 | Nintendo Wii Console
Memory card nor inserted
Three things may go wrong.....
1. the memory card slot is defective
soln -- blow into the slot to remove any dirt. if the problem persists, go to nokia care centre, its better not to lay your hands there.
2. the memory card might not be inserted the correct way
soln -- insert it the correct way or maybe wipe it with a clean cloth.
3. there might be a software problem which might be hindering the phone from reading the memory card
soln -- do a firmware reload, through nokia pc suite
Aug 17, 2008 | Nokia N72 Cellular Phone
SmartParts SP-DPF56E Digital Picture Frame Logo
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
