Question about Weslo Cadence G40 Treadmill
No display when starting treadmill i have no display
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
My PRECOR TRM 800 wiht the P80 console will not work with Quick Start.
If rebooting the treadmill does not fix that, it may have a problem with the Autostop feature. The MCB may need to be replaced to fix that problem.
May 27, 2014 | Precor C956i Treadmills with HR /...
Can you advise please
reset the machine make this: God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Nov 28, 2013 | Precor 935 Premium Series Treadmill
Image 15 treadmill troubleshooting
Reset the treadmills and fix it. God bless you
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Nov 13, 2013 | Cadence Exercise & Fitness
FF appears on the display and treadmill will not operate
please follow this steps and fix it. God bless you
    • 1
    • 3
    • 4
    • 2
Nov 03, 2013 | Proform 695 LT Treadmill
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
Oct 18, 2013 | Horizon Fitness Exercise & Fitness
The term immobilize is on the display panel and I want to start it up. How do I get it going again?
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key
twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill
now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are
disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation,
repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will
display SELECT A WORKOUT again.
Apr 11, 2013 | Life Fitness T5-0 Treadmill Fitness...
Changing kilometer from mile on afg 7.1at treadmill
Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
  1. Turn on treadmill, put safety key in place
  2. Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
  3. Use the SPEED + key to navigate to En93.
  4. Press ENTER once.
  5. Press START to choose unit (miles or km). The display will change accordingly.
    1. Miles: 0
    2. Km: 1
  6. Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
Dec 25, 2012 | AFG 7.1AT Treadmill
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E1 showing on the display. plaese if anyone can solve this proble
I got dkcity treadmill model number- DK5320HRP ' When we press start button the motor does not turn and after few second an error E7 showing on the display. plaese if anyone can solve this proble
Jan 02, 2012 | Exercise & Fitness
Weslo Cadence G40 Treadmill Logo
Top Weslo Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Weslo Exercise and Fitnes Expert? Answer questions, earn points and help others
