Question about Mitsubishi WT-46809 46" Rear Projection Television
JOESTV TURN IT ON PLAYS GOOD 30 MINS THEN GETS BRIGHT CANT AJUST IT.TURN IT OFF THEN ON WORKS GOOD THEN GETS BRIGHT AGAIN
    President:
  • 4,402 Answers
Spay a can of freeze on the vertical ic while it happens if not that ic try others.
i found this on a different page
his set could have a few probems. One common problem on alot of mitsubishi big screens is the surface mount capacitors on the doubler module go bad, but usaully the set stays on but does not have any sound or picture. It is most likely a problem in the vertical. If there is no vertical sweep seen by a certain protection circuit, it will shut down the set to protect the picture tubes from having a line burned into them from just a single intensely bright line being displayed. I have had many a mitsubishi have pico fuses open randomly in the 26 volt line for the vertical and when replaced the set operated normaly. I also had bad solder connection on the vertical output I.C's causing them to short out and open the same pico fuse. There could be oher factors but those are 2 of the most common ones I see. Without actaully looking at the set thats the best I can do. I would say its well worth getting fixed..
Posted on Dec 14, 2007
What are the symptoms of an intermittant problem on a crank sensor ?
Maybe crank shaft sensor or camshaft sensor something else
connect it to the tester and read really errors
Jul 20, 2014 | 1996 Mercedes-Benz C-Class
My tv turns on and works well for about 30 min. During those 30 min the picture will blue-green pixelate all bright colors and whites. I have sound and such but lately it has been starting to cut out (may...
What ever you have hooked to it may have a ground fault. I would replace the cables Iam using first or try a device that you know works good somewhere else and if it does the same thing it is the tv or the cables
Jun 21, 2011 | Westinghouse SK-32H240S Television
I have a Pioneer VSX-917V. After using it for a couple hours and everything working good, the center speaker quits working. I can reset the unit, re-ajust all speaker settings to my prefrence and the...
If new unit, don't waste your time, sounds like a faulty "Sound Card". possibly a slight hairline crack which only shows up when it warms up, yet after a few mins switched off, cools reconnects and so plays?
Dec 26, 2010 | Pioneer VSX-917V-K Receiver
Screen bright blue, wont turn off or on
Sounds like a Power Management problem.
First unplug the power cord and remove the battery. Leave off for 30 mins, then pop the battery back in and try to power up.
Failing that, follow this link on Apple's site. http://support.apple.com/kb/TS1365
Apr 04, 2010 | Apple MacBook Pro Notebook
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
My laptop sceen goes black when playing movies.
if the audio still works, try lowering the hardware acceleration. Set it to none. If it works, try increasing it until you get to the highest setting that does not cause problems. You may also need to reinstall and/or update the video driver.
Updating the BIOS can also help.
Feb 15, 2009 | HP Pavilion dv6000z Notebook
Yes my nickname is cztop i have a mitsubishi big screen tv & need guns ajusted
try unplugging tv for 30 minutes remove all speaker away from tv and anything magnetic after 30 mins turn back on try that
Aug 23, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Tv problem
cant remember how to reset the lock key but its in the manual and if u lost it u can get it online at jvc.com.....good luck
Mar 13, 2008 | JVC AV-27320 27" TV
Sharp 32sf560 TV
Good day
You an adjust the screen brightness on the rear portion of your units flyback. Then the intensity of the color will change.
chris
Feb 02, 2008 | Sharp 32C241 TV
Mitsubishi WT-46809 46" Rear Projection Television Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
