Question about Energizer Eveready Utility Lantern Uses 6V Lantern Battery
Installing a lantern battery - Energizer Eveready Utility Lantern Uses 6V Lantern Battery
I am trying to find battery location for Coleman Model 5327A750
William, went to Coleman site, looks like you remove screws on bottom of lantern to access and change battery.
Check the attached links to your manual,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://r1.coleman.com/Manuals/5327.pdf
Rugged Rechargeable Family Size Lantern
Coleman Rugged Rechargeable Lantern Replacement Parts Flashlights...
Battery Buyer Batterybuyer com
Mar 06, 2016 | Coleman Camping, Backpacking & Hiking
How do D batteries install into a Rayovac camping lantern?
If there is no access panel on the bottom for the batteries then the base itself must unscrew to give you access. I'm sure that will work for you.
Oct 04, 2014 | Rayovac Krypton Lantern 4 D SP4D Kb
Replacing a 6 volt battery
Check that the contacts where the springs on the battery make contact in the light to see if they are corroded. If so scrape or sand them off.
Jan 09, 2013 | Energizer Eveready Utility Lantern Uses 6V...
Installing the batteries in this lantern
Flip it upside down. some have a threaded cap you untwist off, and some have a screw you remove.
Nov 14, 2012 | Rayovac Krypton Lantern 4 D SP4D Kb
Rayovac 360 sportsman lantern wont work
Since batteries and bulbs are new/ok, check for a bad connection. In older version using 4 lantern batteries, open the battery compartment by unscrewing the knob on top of lantern. The lantern bottom comes off once unscrewed (of course you did this to change batteries). There is a "C" clip on the lantern center shaft; remove this by prying with screwdriver or with pliers. Carefully raise the battery contact plate and check slip-on wire connections. Clean as needed (Scotch-Brite works well) and reconnect. Squirt some contact cleaner in exposed switches, work switches back and forth. Inspect circuit board for obvious corrosion or damaged parts (this damage may "total" the lantern). Re-install plate aligning grooves with ribs. Install batteries and test.
Nov 01, 2012 | Camping, Backpacking & Hiking
How do you light a Chinese lantern?
Modern Chinese lanterns made for home decorations are filling the current market. These are available in shops coming in different shapes and colors. The current designs contain strings or cords that are used to supply power and for attaching the indoor home lanterns available. These lanterns use minimal amount of power and are able to use a battery for a long period. Hanging these lanterns on the wall creates a good finished look. The Chinese lanterns are easy to light up using their battery power sources as well as they are permanent objects unlike outdoor lanterns used during festivities and are later released to the skies above.
Aug 24, 2012 | Light Boating
I am trying to find a 120 Volt AC adaptor for my Swissgear lantern.
The adapter need to match the charge voltage requirements of the battery in the Swissgear lantern.
This voltage maybe written on a label on the lantern.
i suggest go to the shop where you purchased the lantern for the charge adapter.
Jun 02, 2012 | Computers & Internet
User's manual for coleman rechargeable lantern model # 5348-700
There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Jan 22, 2012 | Coleman Rugged Battery Powered Lantern...
Energizer Eveready Utility Lantern Uses 6V Lantern Battery Logo
83 people viewed this question
Top Energizer Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
NicK Hale
Level 1 Expert
Tom Chichester
Are you an Energizer Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
