Question about Rotary Variable Speed Tool Kit W Flex Hose For Dremel
How to test a dremel armature - Rotary Variable Speed Tool Kit W Flex Hose For Dremel
Dremel 395 Rotary tool won't turn on or won't stay on but a second or two
Electrically speaking there are a few items to check.
1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation.
2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch.
Some parts can be purchased on the below link.
http://www.ereplacementparts.com/dremel-395-f0130395ca-corded-multitool-parts-c-15440_15456_15474.html
Or contact a dremel service center from the link below.
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
Apr 27, 2011 | Dremel Variable - Speed Multipro Rotary...
I was working with the dremel and it shut down and would not turn back on, the motor was not hot. I'm wondering if it has anything to do with the brushes in the side of the motor housing?
My dremel started doing that too. If I rubbed the sanding drum along a piece of wood, it would start up again. I think the brushes and the copper armature get glazed over with non conductive dust and possibly insulation smoke which disconnects it enough to stall out. Change the brushes to the new ones in the kit. After a year of heavy use mine slowwed down to about 300 rpm and then died. A very nice tool but I prefer the Makita which is about three times this size just because it is longer lived.
Apr 09, 2011 | Dremel 395 Variable Speed Multipro Rotary...
I plugged my dremel 395 to a 220 volts outlet in Hong Kong, not realizing that it works only on 110 volts. Now it does not work, even with a power converter attached. What needs replacing to make it work?
It is with regret that I must inform you that you will probably have to replace the whole unit, the field coils will have blown and almost certainly the armature - your did give it a 100% over voltage shock. The prices of the parts will be more than the cost of a new machine.
Mar 29, 2011 | Dremel 300-N/55 300 Series Tool Kit
Collet on my dremel is jammed and the hold button is not strong enough to keep it firm while trying to unlock it.
I would hate to try to jam something into the fan, so I think it would be safer to split the case open and then put the armature in a vise. I am pretty sure you can still do that with this model.
Another alternative would be to use an air impact on the collet, since it works on inertia and does not need the shaft to be locked. Of course then you would need to be able to slip a socket over the collet hex part, and you may have to cut off a bit in order to do that.
Feb 28, 2011 | Dremel 400 Xpr Rotary Tool
My dremel multi max has a problem with the switch. When I turn it on, it works for awhile then stops, then starts back up... ???? I have to fiddle with it to get it going for 10 or 15 seconds, then the...
Most of our issues with Dremel tools is with the plastic brush holder. If the tool is used for exetnded periods of time or 'leaned' on too much the holder will get hot enough melt and keep the brushes from contacting the armature properly. Try taking your brushes out, if they don't slide in and out of the holder freely you may need to file or cut away any plastic that is holding the brushes off the armature. This may require you taking the brush holder out so you don't damage the armature. Be careful with the brush holder, it is not available as a replacement part.
Jan 05, 2011 | Dremel Garden
I want a replacment armature for a Dremel 396
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams..
If you need more help come back.
Post / thumbs / testimonial are welcome!
Dec 17, 2010 | Garden
I have a Dremel model 395T6 (F013 0395 04). The other day I was using it to cut plastic. It worked fine and was turned off during operation. When turned back on for the same operation there was no sign...
Well, yes you can measure the switch, look for continuity. I suspect something else is wrong, some models had armature issues. Measure the coils and armature for continuity.
Oct 11, 2010 | Dremel 300 1/40A "Multi Pro" Rotary Tool...
Unit wont run at all, yes I do have power, took apart and 1 of the brushes was stuck in slot and it looks like its been really hot.do I need to replace the switch assy. dremel 395 type 4,
I would think that just the brushes, they should slide freely in the slot. check also the condition of the armature for arcing or raised commutator bars.
Aug 07, 2010 | Dremel Variable - Speed Multipro Rotary...
Motor gets hot very quickly and the brushes are still very good
could be the bearings or the armature rubbing the field. if you had it apart make sure the electrical parts are seated fully.
Apr 18, 2010 | Dremel 400 1/6 120V Xpr Rotory Tool...
Worn front bearing on Dremel Multipro
You can put new grease into that bearing without removing it by following the steps in this M.S. Paint drawing I made. After a bit of protest, mine started running a lot better.
Dec 20, 2008 | Dremel Variable - Speed Multipro Rotary...
Rotary Variable Speed  Tool Kit W Flex Hose For Dremel Logo
65 people viewed this question
Top Rotary Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
raysaw
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
