My nook will not turn on - Office Equipment & Supplies
    Problem Solver:
  • 5 Answers
Without further explanation, pictures or details of what you tried, it's hard to tell what exactly is wrong with your Nook. However, assuming that the battery is still good you will need to "reboot" your Nook.
Unlike other tablets, there is no reset button, but you can try this.
While pressing the Nook button (upside down u on the front of the tablet), press the power button on the side. You will need to hold it for couple of seconds.
Posted on Mar 10, 2014
How do I transfer my library on my old Nook to my new Nook?
How to transfer books from old nook to New Nook? Therefore, to transfer your Nook books to a new Nook, all you have to do is perform a synchronization between the Nook and your Barnes and Noble account. Press the "Power" button on your Nook and hold it down for two seconds to turn on the device. The Welcome screen opens.
How to Transfer Nook Books to a Different Nook ' Chron.com
smallbusiness.chron.com/transfer-nook-books-different-nook-27403.html Search for: How to transfer books from old nook to New Nook?
How do transfer my library on my old Nook to my new Nook Google Search
Feb 07, 2017 | Tablets & eReaders
I have charged my Nook HD but it won't turn on. What can the problem be?
Do you have the charging graphic as in this image Nina?
How to Reset Nook HD
If yes, send it back. If not, your charger is faulty. Try charging with a computer USB.
Jan 21, 2016 | NOOK HD 7 Tablet
Will not take a charge a
Barnes & Noble Nook HD
Jan 01, 2016 | Barnes & Noble Nook HD
How do I turn it on?
  • Charge your new NOOK Tablet for 3-hours from a wall outlet using the Power Adapter and USB Cable packed at the bottom of your NOOK Tablet box.
  • Turn on your NOOK Tablet by pressing the power button on the top left side.
Dec 29, 2015 | Barnes & Noble Nook Tablet
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
Why my nook tablet will not turn on ?
If the screen is off and won't turn on, make sure the battery has a charge. Plug in your device for 30 minutes before trying anything else. If it is on or if the battery has a charge you may need to "hard reset" the Nook. Although this is very uncommon, it may happen. Below are a few solutions that may help.
  • Hold down the power button for 10-15 seconds. The Nook should power off and you can turn it back on again. Everything should work normally.
  • If that does not work you will need to hold down the power button and the "N" button for 10 or more seconds. Again, this should force your device to power off and you can start it up normally.
  • Take out the N2A Card and try the same steps again. Your Nook should boot up into Nook mode. You'll have to restart it again with the N2A Card in to boot up in Android mode.
One of the tasks above will usually correct this issue unless you have a hardware problem with the Nook. Our cards cannot cause hardware problems unless they are forcefully inserted wrong. If you determine you do have a hardware problem you will need to take the Nook back to the retailer if it is still under warranty. The Nook usually comes with a one-year (non-accidental) warranty through Barnes & Noble. Some retailers, like Best Buy, exchange them in the store under warranty.
Don't forget to hold onto your N2A Card until they return your Nook!
If you still have any kind of issue thenhttp://www.tablethelpline.com/nook-support/ you can take Nook Help from experts by calling nook customer service number.
May 16, 2014 | Barnes & Noble nook color eBook Reader
Nook HD will not charge or turn on
It may be your cable, I jsut had to replace mine and I had it under a year, the Nook is known to have troubles with the cable. See if your Nook is still under warranty and call customer service, if not, you may have to buy a new one.
Mar 07, 2014 | Nook HD+
HD Nook wont light up could it the LCD or power switch?
my nook tablet shows the green light that it's fully charged but when trying to turn it on nothing happens the screen does not com on or the nook symbol does not light up . can any one help me out here
Sep 28, 2013 | Nook HD+
91 people viewed this question
k24674
jasbo
jasbo
