Question about Magnavox ZV427MG9 DVD Recorder/ VCR
Vcr player won't work. Brand new unit.It's hooked up with Hdmi cord. Dvd will work. But for the vcr it says no signal
    Champion:
  • 236 Answers
To connect the VCR to the TV use the far right VIDEO OUT, AUDIO (R for RIGHT, L for LEFT) jacks to connect to TVs VIDEO IN (yellow) and AUDIO IN jacks.
Posted on Mar 06, 2014
How do you hook up cords to cable box & television
WELL IT SEEMS U HAVE TWO PROBLEMS :
1ST YOUR rF SIGNAL IS NOT GETTING THRU , THIS IS A ROUND CABLE WITH A SCREW ON END TO IT , THIS ONE MUST 1ST COME INTO YOUR HOME AND GO TO CABLE BOX , THEN LEAVE OUT OF CABLE BOX AND ENTER VCR THEN LEAVE OUT OF VCR AND GO TO RF INPUT OF TV ( HAS TO BE HOOKED THIS WAY WONT WORK ANY OTHER WAY) SET OUTPUT OF VCR TO CHANEL 3 SET OUTPUT OF CABLE BOX TO CHANNEL 3 SET TUNER OF VCR TO CHANEL 3 , AND LAST SET INPUT OF TV TO rf CABLE ,CHANEL 3 , NOW YOU CHANGE CHANELS ON CABLE BOX only
2ND YOUR DVD PLAYER HAS NO RF OUTPUT SO YOU NEED TO CONNECT BY ONE OF THESE MEANS (HDMI, RGB, COMPOSITE) ALL THESE REQUIRE A DIFFERENT CABLE YOU DECIDE , THERE HOOK UP IS PRETTY MUCH ONE WAY SO I WONT ELABORATE ON EACH METHOD , BUT TV NEEDS TO BE SET TO CORESPONDING INPUT TYPE YOU DECIDED ON
Nov 11, 2015 | Magnavox DV220MW9 DVD Player VCR
We just purchased a Samsung TV, and have been using a RCA DVD/VCR player/recorder, Model#: DRC8295N, Serial#: XXXXXXXXX We have Direct TV and before the new tv was using one of their DVR player/recorders....
The problem with your DVD/VCR is that when you hooked up your new TV you probably removed the power cord for the DVD/VCR during installing and running your new wires and such.
Your DVD/VCR has known problems in the power supply. This is very common. When unplugged, this allowed the capacitors to discharge and now wont work at all. It is very possible that if you left your DVD/VCR plugged into the AC wall socket it might begin to work after a couple of days. I wouldn't plan on it though.
Your DVD/VCR will need power supply repairs.The cost should be around $100 dollars.
if you would like one of our stores to repair this for you we would be happy.
please visit http:www.albiontvandcomputer.com
You can send us the unit and we can repair this for you and return in about a week.
Jan 18, 2011 | RCA DRC8295N DVD Recorder/VCR
We just got a brand new dvd/vcr combo and the dvd player works, but the vcr only plays the video and no sound. Have tried 5 different VHS tapes. DVD player works flawlessly.
How do u hooking up this thing,up by a AV component video RYW signal cable to an analog tv,a LCD,plasma tvs or an a HDMI cable to a LCD or a plasma tvs?More informations please?
Dec 11, 2010 | Magnavox DV225MG9 DVD Player VCR
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
I have a DVD1001 DVD VCR combo how do I hook DVD combo to my tv
Use output of combo player to input of TV. Use what ever available input you have left on you TV. HDMI or Component input is best, but others will work.
Dec 30, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Hooking my DVD player up to my HD converter
connect as follows,,,
converter-->VCR-->TV
DVD-->VCR-->TV
watch DVD as before, when VCR is off, the converter will show up on the TV
Feb 19, 2009 | Televison & Video
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
Can't receive proper dvd/vcr signal
Your Toshiba TV uses the American NTSC standard.
Your DVD/VCR uses the Australian PAL B/G standard.
Unfortunately the two are not compatible as they stand, but there may be an option in the DVD/VDR menu to force the output to NTSC. This varies from make to make.
Another option would be to modify your main DVD player to make it multi-region so it will play ALL of your DVDs. Some models can be modified with a simple handset code, some can be modified with a software update, and others need an internal modification.
Post your make and model, and I can advise you on modification.
May 14, 2008 | Televison & Video
Recording TV
Hi.. it looks as if that particular dvd/vcr is not compatible with the coding digital signals that the hdmi is putting out so it's not converting the signal over correctly.. if you try just using the regular analog cable instead of the hdmi, that might solve your problem.. i hope this helps..d
Jan 24, 2008 | Samsung DVD-VR357
Magnavox ZV427MG9 DVD Recorder/ VCR Logo
89 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
