Question about Pantech Element 4G LTE Android Tablet
Low storage I installed micro scan disk,, still getting low storage notifications
How to update tablet firmware
If there is a new version available, follow these steps :
Tap "check update" in "Settings"
Then go to "about" and go to "system update" to check if the firmware is latest.
Steps to update :
1) Go to "Need Help?" page of ASUS official website http://www.asus.com/support to download ZIP file of firmware.
2) click the ZIP file after downloading is completed
3) Connect your tablet with PC via micro USB cable, and copy the ZIP file to the root dictionary of internal storage of tablet
4) Detach micro USB cable from the tablet to make the notification for firmware update popped up on status bar
5) Tap "System Update File Detected.." and follow steps to update firmware
Now your firmware is updated.
Nov 21, 2017 | Tablets & eReaders
I have 408mb but it says i have insufficient space to download an app thats only 9.86mb...what's the problem?
Kindly go with what your phone or tab says please;it's the only way you can go past where you are stopped/stuck at the moment.
1. I suggest you get a micro SD card inserted in your phone/tab.
2. Open settings and navigate to apps/applications.
3. Click on any app you installed.
4. Look midway down and you'd notice two horizontal bars with
CLEAR DATA
and
MOVE TO STORAGE/SD Card
Select Move to Storage (or SD card) and wait for process to complete.
Do this for a number of apps you installed.
This method/tip/option helps free up Space so your tab/phone can allow you install more apps.
Oct 08, 2017 | Tablets & eReaders
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
Use of storage card
Gordon, Move the stuff on tablet to the SD card to free up space.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Move Android Apps to an SD Card
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
internal storage full how to move to SD card
Aug 04, 2016 | Tablets & eReaders
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
Jul 10, 2016 | Tablets & eReaders
We installed micro sd card in my son's tablet, but still won't download games. Says insuffiencent memory.
Dependant on model of tablet you may have to change the save love location manually. Go to settings then to storage and from there you should be able to change download storage to ad card. If that does not work go to settings then to ad card and select as download storage
Oct 09, 2015 | Tablets & eReaders
How does ram vs internal storage work on tablet?
There are 2 storage in just about every smartphone or tablet. There is an internal storage, usually about 1gb. or 2gb. And there an internal SD storage, which is not same as the external micro sd card. RAM stands for Read Access Memory, it will not work as storage. Now, when you download an app it is usually save in the internal storage. If you move an app without an external micro sd card inserted, you are moving them to the internal SD storage. If possible got to setting>storage and check how is the storage divided, if you insert the external micro sd card it should display 3 separate bars. Also, another way to move apps and other things around is by using ES File Explorer. Check that out first and I hope you do resolve the problem, best of luck.
Jan 22, 2015 | Tablets & eReaders
How do I get my external SD card to work in my tablet?
Check the GB on the SD card. Perhaps you need more GB. Try a 16 GB
Sep 13, 2014 | Tablets & eReaders
Why does it says low on storage space when all i download was an app called kik
there are 7 apps in the kik family, you can remove some of the other apps that were installed or you can get an Micro SD card up to 32 gigabytes and move the apps to the card if possible
Dec 27, 2013 | Iview Cyberpad 756TPC Tablet
How do i download music from my laptop to tablrt
I highly recommend installing DoubleTwist after you follow the instructions below. The DoubleTwist program lets you do media sync to any android device, it's slick and simple.
Connect your tablet to the computer using the included USB cable (small end to tablet, normal sized USB end to PC)
A USB icon will appear in your notifications bar at the top of your tablet's screen, drag the bar down to open the notification.
From here you'll choose to mount the storage drive (either internal or an external card if you have an SD card installed).
Once that's done your tablet should appear as a "Mass Storage Drive" or another hard drive on your PC. From here you can drag and drop files into it, or use DoubleTwist to do that automatically.
Feb 28, 2011 | Coby Kyros 716829701508 Tablet PC
Pantech Element 4G LTE Android Tablet Logo
20 people viewed this question
Top Pantech Tablets & eReaders Experts
Computer Repairing
Computer Repairing
Are you a Pantech Tablet and eReader Expert? Answer questions, earn points and help others
