Pinout for T6476 battery - Computers & Internet
Need the pinout for a insperion laptop battery type u1223
Please bear in mind it is extremely dangerous to take a battery pack to pieces. I will not be held responsible for any injury howsoever caused!
Inside DELL D610 battery connector pinout and signal timing
Feb 08, 2016 | Computers & Internet
How do I determine the battery pinouts for my Dell Inspiron 1526
the pin outs for the batteries in general are:
1 +Batt - Battery output voltage
2 SMB_SDA - System management Bus Serial data
3 SMB_SCL- system managemant bus Serial Clock
4 Batt_temp - Battery temperature monitor
5 battery_present or Battery ID
6 GND - ground
the SMB_SDA & SMB_SCL are used by IO controller chip in mainboard to communicate with the battery( battery type , charge level), and you can not use other model laptop batteries because it will not match with the bios whitelisted battery type.
no way you can fake the battery, instead you can flash the bios by modifying the flashing programs config.ini file so that it ignores the battery
Jun 24, 2014 | Dell Inspiron Computers & Internet
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
I need the pinouts for a nintendo wii headset (usb pinouts)
The USB interface is standardized. Knowing the pinouts isn't useful for creating your own headset, but here are the pinouts anyway:
http://pinouts.ru/Slots/usb_pinout.shtml
Feb 03, 2013 | Nintendo Wii Console
Pinouts power supply for hp d530 ultraslim
Hi lantzgema,
I looked up the specs of your d530 and all I could find out is that you have a 150 power supply, calling HP technical support was no help at all.
I did find some pinouts you can look at and determine which one exactly you have. Hope this help out.
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-24-pin-12v-psu.htm
http://pcsupport.about.com/od/insidethepc/a/sata-pinout-15-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/molex-pinout-4-pin-psu.htm
http://pcsupport.about.com/od/insidethepc/a/atx-pinout-4-pin-12v-psu.htm
If this is still not what you have there are other pinouts at the same website.
Dec 28, 2010 | Computers & Internet
What is the pin layout for the rs232 connector on the F5U409v1 adapter from belkin.
The pinouts are in numerical order
1 2 3 4 5
6 7 8 9
Pin signals:
1.Data Carrier detect
2.Rx
3.Tx
4.Data Terminal Ready
5.Signal Ground
6.Data Set Ready
7.Request to Send
8.Clear to Send
9.Ring Indicator
Dec 20, 2010 | Computers & Internet
With the zd8210ca off with power cord plugged into laptop also battery is in laptop. Battery light on front panel is blinking. With laptop booted up battery condition show charging at 0%. Does any one have...
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 14, 2010 | HP Pavilion zd8000 Notebook
I need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Dec 11, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
