Question about Radio Communications
Radio stopped receiving all of a sudden while driving down the road. When I removed the cover it smelled as though a component had burned up
    New Friend:
  • 60 Answers
If you were talking on it prior to it going south, you may have burned out the transmit final output transistor (Final). If the Finals shorts out, the receive goes way down.
Posted on Feb 21, 2014
My sound system had a smell of burning from the main unit and suddenly stopped working. I switched it off and now although all the function lights are on there is no sound from the system but no longer a...
radios often have components that over heat and burn out. Once burned out they have to be repaired or replaced. Ford F150 trucks are notorious for that.
Mar 02, 2015 | Cars & Trucks
Replacement engine warranty
Are you putting too much clothes in at once? Bad motor. It could be bad bearings causing the motor to go bad.
Dec 28, 2014 | Washing Machines
I have a Connex 3400 Hp and it stopped receiving all of a sudden while driving down the road and the needle on my meter is dead on 0. I've doubled check to make sure all my knobs and switches we're in the...
check for a fuse bulb for the RX section i would have a radio engineer look at it as you smell stuff
its also not a good idea to drive around with known faulty electronics in your car its a bad problem just waiting too blow up in your face... so.. dont leave electrical issue in cars your family depends on
Feb 16, 2014 | Connex CX-3400hp AM/FM 10 Meter Amateur...
Was driving my Ford F150 down highway, check engine light came on, several mintues later, the truck died. I pulled off to the side of the road. Still have lights, radio, etc, but when turn key, nothing...
May have a wire rubbing somewhere ... check under the truck ... oxygen sensor wires ... if not running or on the exhaust ... see if you don't have wire rubbing on the drive shafts somewhere.
Oct 22, 2017 | 2004 Ford F150
Burned smell coming inside the car(pathfinder 1998) while long journey.
Dear Sir,
As you said while driving burning smell comes, if it occur in this condition 1. at hill side road 2. you trying go up side on slope or 3. you are in traffic on slope. basically what happen due to over riding or you can say you are in 2nd or 3 rd gear and you moving towards up side you will press clutch half and press accelerator , that will cause clutch burning if having problem in pickup then get replace clutch kit assay,if you are not facing any problem with car pickup you can drive it till you feel problem in pickup. it will not stop suddenly it will give indication with pickup loss then go and replace it .till drive the car don't worry. Thanks
Yogesh
Nov 03, 2010 | 1998 Nissan Pathfinder
My Rav 4 1997. i smells like burning (strong odor) every after parking it. It's not coming from the hood. It seems like it's coming from underneath or from the tires. Can you please give me an answer.I'm...
It sounds like differential lube. gear lube.A little bit go's a long way.check the seals pinon and axles.the cover on the differential look at the vent too.also gear lube on brakes it's not good.some times you have to pull tires off to see the oil.
Feb 25, 2010 | 1997 Toyota RAV4
91 toyota camry- while driving (in the rain) radio suddenly stopped working, although station display remained lit and numbers were displayed. I smelled smoke, of an electrical nature. Drove home, parked...
You have a failed output section inside the radio. If you remove the radio, and take it apart, you will see some burnt capacitors at the very back side of the PC board. This is, unfortunatly, a very common problem with those cars. You are going to have to get another radio, the expense for the manufacturer to fix is is more expense than a replacement. Sorry, but I have seen this situation too many times.
Oct 23, 2009 | 1991 Toyota Camry
A.C. Stopped working.
you will need a new pump.
Jul 17, 2009 | 2003 Mitsubishi Outlander
Burning smell when I drive in 1993 Honda Civic 4 door
some times clutch palate and brake bads makes smell,
even if you forget to release hand brake.
Oct 23, 2008 | 1993 Honda Civic 4 Door
Odd odor
Yes..... that odor you smell was a component burning out on the circuit board. if you were lucking it only burned out one thing. fixable....if you have the time. actually anything is fixable it usually boils down to the cost of fixing it vs replacing the item.
Robert
Sep 26, 2008 | Grundig S350 AM/FM/SW Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
