Question about Metra 99-5717 2004-2007 Ford Taurus Radio Dash Kit
Heater and defrost not working
No heat
    Sergeant:
  • 182 Answers
Low on antifreeze, not enough in circulation to make it flow through the heater core steadily.
Posted on Nov 16, 2014
Heater goes off defroster comes on cant shut off intermitant?
THAT DOES NOT MAKE SENSE THE HEATER GOES OFF WHEN THE DEFROSTER COMES ON ? WHEN THE DEFROSTER MODE IS ENGAGED THE HEATER SHOULD COME ON. IF DEFROST MODE IS ON AND NO HEATING THEN i WOULD CHECK THE HEATING ELEMENT WITH A MULTI METER. IF its intermitant then I would check the defrost timer?
Mar 13, 2015 | Refrigerators
1996 Montero Heater Blower not working
I assume your heater setting is electric control, if so either your defrost and floor heat switch failed or wire problem. For the air not hot, check the heat control valve on the top of the hose it should be in front of the firewall. I don't know your car is using mechanic valve or electric control valve. Anyway check there first. Good luck.
Nov 24, 2013 | 1996 Mitsubishi Montero
2001 Ford Taurus No Heat I am having trouble with
possibly the bled door is stuck open so only the cold air from a/c works when on defrost vs closing to allow heat to cycle through the system as defrost runs through the a/c system
Sep 18, 2013 | 2001 Ford Taurus
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Freezer is not defrosting properly , I already change the thermostat, my refigerator model is TBX74UL01 OR TBX74UB01.
If the thermostat is replaced, but still its not defrosting, then two possibilities, either weak defrost heater,Heater is the part which heats and it defrosts, if the heater gets weak, then unit will not defrost properly.And it will take more time to defrost, and till that time, again frost gets collected.---------- But if defrost heater is ok, then problem is defrost board.The defrost board is the part, which controls both thermostat and defrost heater.-----------
This problem is called defrost problem.-------------
So first thing you try is , perform, manual defrost reset procedure.---------
The manual defrost reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. Then check,if same frost is getting collected, then its defrost problem,. If it's again building up ice that means the unit is not defrosting. It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. IN YOUR case, defrost thermostat is already got replaced, so ignore thermostat, but other two possibilities needs to be checked.----------You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Sep 19, 2011 | GE Refrigerators
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
Fridge freezer problem
Sounds like the defrost system of your freezer is not working. It could be either the defrost timer, defrost thermostat or the heater has a problem. The defrost timer turns off the compressor periodically to sent power to the defrost heater via the thermostat. The defrost heater then powers up and heats the evaporator coil to melt the accumulated ice buildup on the cold coils. Most likely issues are that the timer motor is not advancing the timer or the heater itself has burned out.
Jul 14, 2010 | Freezers
I have a 1996 cherokee country. When I use y
Could be the control switch itself. Or possibly the actuator that moves the door from defrost to heater. With the heater on, try switching from defrost to heat and try to hear if you can hear anything in the dash operating.
Mar 09, 2010 | 1995 Jeep Cherokee
Metra 99-5717 2004-2007 Ford Taurus Radio Dash Kit Logo
114 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
