Question about BAFX Products 2 Pack - Anti Shock Hiking / Walking / Trekking T
How to assemble
A what do I do with the round disc, with the center hole, that is attached
How to remove rear struts
Remove or disconnect the following:
NOTE
Hold the hex on the attaching link stud while breaking the nut loose. The attaching link does not have to be removed from the strut.
Rear wheel
Caliper assembly and rotor from the hub, if equipped with rear disc brakes
Brake flex hose from the support bracket and wheel cylinder, if equipped with rear drum brakes. Plug the brake flex hose to prevent system contamination. Do not allow the rear caliper to hang by the brake hose. Support the caliper off of the frame with a strong piece of wire.
Speed sensor cable routing bracket and tube, if equipped with Anti-lock Brake System (ABS)
Lateral links to the rear spindle assembly bolts
Rear strut assembly-to-stabilizer bar attaching link at the stabilizer bar
Remove the rear spindle-to-strut assembly pinch bolt. Install a center punch in the hole on the spindle and tap the punch into the hole until jammed. This will spread the spindle casting allowing it to be removed from the strut.
Using a hammer, tap on the top surface of the spindle, driving the spindle down and off the end of the strut assembly. Let the spindle and assembled components hang from the trailing arm while the strut is being serviced.
From inside the trunk of the vehicle, remove the 3 upper strut mounting bolts and remove the strut from the vehicle.
Disassemble the strut by performing the following procedure:
NOTE
Service of the coil spring requires the use of a coil spring compressor tool. It is required that 5 coils be captured within the jaws of the compressor tool.
Apr 02, 2015 | 2002 Chrysler 300M
Whats a shower screen?
where the basket attaches look under Neath you will see a round disc with a screw in center remove it disc should drop out make sure it is clean if blocked brush with washing up liquid until you can see the holes are clear rinse well reassemble you will then have better pressure and steam
Jan 25, 2013 | Gaggia Classic Brushed Stainless Steel...
Don't have the directions to put evenflo exersaucer together, need help. Is there somewhere I can get the directions? reg. number 07T-0538604
Instructions
    • 1 Place the large, round base on the floor. The outwardly curving edge should be facing downward.
    • 2 Attach the three pedestals to the base. To do so, insert your finger into each pedestal and loop the spring within around the hook found on the base in the appropriate holes. Insert the three plastic tabs on each pedestal into the base, locking them into place.
    • 3 Press the wider end of a lower leg assembly onto each pedestal piece. By wiggling the lower leg assembly side to side, you will eventually snap the pieces into place.
    • 4 Hold the seat ring in your lap with the open edge facing upward. Press each of the six wheels into the wheel holders around the edge of the seat ring. Each wheel will snap into place when positioned correctly.
    • 5 Insert the cloth seat into the seat ring, aligning the diamond on the cloth seat with the triangle on the seat ring. Each plastic tab lining the edge of the cloth seat attaches to a peg on the seat ring. Snap these connections into place.
    • 6 Hold the Exersaucer tray on its side and press the seat ring into the center. Once the seat ring snaps into place, it should be able to spin in place.
    • 7 Attach the three spring caps to the Exersaucer tray. These spring caps cover the three large holes in your tray, and are attached by a firm clockwise twist.
    • 8 Attach the upper leg assemblies to the upper leg crowns. These crowns act as the "socket" and the upper leg assemblies act as the "ball." By pressing them together with a click, the upper leg assemblies can twist and rotate in place.
    • 9 Turn the tray upside down and press each upper leg crown base into the round holes in the tray with a firm twist. Each upper leg crown features a height adjustment hole, which will face outward when properly attached.
    • 10 Turn over the tray so that the upper leg assemblies are facing downward. Insert each upper leg assembly into a lower leg assembly, being sure to pull away the height adjustment tab to allow the assemblies to slide together.
    • 11 Press each toy into its respective port on the surface of the tray. The toys each have a distinct base, which clicks into the correspondingly shaped tray port
May 10, 2011 | Toys
What is the location of the fuel pump in the fuel tank
remove large lock ring on top of tank mostly center of tank. and fuel pump assembly will pop out, assembly contains fuel pump small round silver cylinder,has two wires attached, rest is float , pump screen and sending unit.
Apr 09, 2011 | GMC Sierra Cars & Trucks
Need assembly manuel for Jenny Lind 012614 where can I find it online?? Every website takes me to another I am very frustrated....didn't think it would be such a ordeal to locate a manuel online???? Is...
Evenflo Jenny Lind Crib has been recalled.
When you call to get the kit to fix the problem (800) 356-2229 you could ask Evenflo directly!
Here are instructions without a manual...
1. Lay the headboard on the floor in front of you with the bracket holes and model number facing you. Use 2 ¾-inch wood screws to attach the L-bracket and the latch bracket to headboard. The L-bracket has 3 holes and attaches to the holes on the lowest section of the headboard. The latch bracket only has 2 holes and goes directly beneath the metal bracket for the mattress that is already attached. It should face toward the center of the headboard. Once you're done, complete the same procedure on the right side of the headboard. Then do the same for the footboard.
2. Stand the headboard up so you can attach the rails to it. First, place the cross dowel (the small piece of wood with a hole in the side of it) into the hole on the underside of the top rung of the rail. Then put a second dowel in the top side of the bottom rung. Line the left rail up with the headboard at a 90-degree angle, placing it in the brackets you just installed, and insert a 2 13/16-inch machine screw into each of the 2 holes on the front side of the headboard (the side that will face outward). Tighten each screw with your screwdriver until it hits the cross dowel. Then turn the cross dowel clockwise to lock it in. Do the same for the right side and then for the footboard.
3. Slide the mattress platform (the bottom of the crib) into the stabilizer rails (easy to distinguish, since they are the same size as the sides of the platform), putting the longer ones on the sides and the shorter ones on the ends. It will slide in easily. Use 5 ¾-inch screws to attach the hanger brackets to the corners of the platform. The holes are predrilled and you can only put the bracket on one way to match them up, so there is little worry that you will attach it wrong.
4. Put the support brackets (the straight, flat ones) on top of the predrilled holes in the underside of the stabilizer rails. Screw them in with ¾-inch wood screws. Then place the hanger brackets in the slots that were preinstalled on the headboard and footboard. Choose the level that will suit you best. Evenflo recommends the top two for infants.
5. Snap a caster (the round disc) on the bottom of each foot of the crib. Check that all your screws are tight to keep your baby safe.
Jan 29, 2011 | Evenflo Jenny Lind Crib
Access for replacing brake light bulbs: Is it from the trunk or under the rear bumper?
you can access the bulbs from the trunk, remove the covering from the inner back of the rear.
Feb 18, 2010 | 1988 Buick LeSabre
How to change bulb for turn signal indicator
You need to remove the whole taillight assembly. Open the trunk, and you'll see the plastic covering the lower rear part of the trunk, including up and around where the taillights are. On each side, there are two plastic fasteners. Just use your fingernail, or something thin, and pop out the CENTER of the fastener. Don't pull hard, it just comes out about 1/8", do NOT remove the center entirely. Once you pull the center out a bit, the whole thing should pull out easily. Do this on both sides.
Now grab the middle section and while wiggling, pull it straight up. It's held with 4 push in clips that slide onto the plastic part. It's very snug, but it'll come out with some wiggling and pulling up.
Now you can pull the fabric covering the back of the trunk where the taillight is. Remove the 4 metric nuts, and the whole unit will be able to be pulled out. Be gentle, the wiring is still attached from within the trunk. I found it easier to work on if you push the connector/grommet inside the trunk through to the outside. It just pulls back easily when you're done.
Turn the fitting on the back of the taillight assembly counter clockwise about 1/8-1/4 turn and it comes out. Takes standard type bulb. After replace, before reinstalling, try the light. Reassemble in reverse order.
Put nuts on taillight assembly, snug up. I found I could loosen the nuts by just holding the socket in my fingers, so only tightened the same way, no wrench. Smooth the fabric from the sides of the trunk back in place over the taillight area. Take the plastic cover and note the 4 clips that hold it in place, as well as the round plastic that helps align it. Ensure the clips are correctly on the plastic, one of mine slid off and remained in the car/hole. I just used pliers to pull it straight out, then slid it in place on the plastic. Align the round pins in the metal of the trunk and push straight down in the 4 places the clips go.
Ensure the holes in the plastic, and fabric, line up with the hole in the metal on the sides by the taillight. Holding the plastic clips with the center slightly out, push them in, then push in the center and they'll hold.
Close trunk and re-test lights and you're done!
Nov 08, 2009 | 1994 Mazda 626
The belt has come off how does it fix back on?
first place the belt onto the bottom of the turntable, it will be kind of snug but not very, replace turntable onto centerpin, remove rubber disc, spin the turntable slowly and look thru the opening at the same time, on the right side you will see a gold colored post, that is what you want to run the belt over, just pull it away fron the turntable and around the post
Jun 28, 2009 | Sony PS-LX300USB Turntable
Disc Read Error ( slim PS2)
Ah yes the dreaded DRE... time to replace your ps2 dude, this is the easiest and least headache solution.
Logged too many hours on those poor machines ;)
Aug 18, 2008 | Sony PlayStation 2 (PS2) Console
BAFX Products 2 Pack - Anti Shock Hiking / Walking / Trekking T Logo
138 people viewed this question
Top BAFX Products Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a BAFX Products Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
