Question about Sony VPL-ES1 Multimedia Projector
Sony projector NO power/standby led. Was working fine recently, bulb replaced less than 500 hours ago.
I have tested power cable. Projector will not take power and not activate red standby power led. I do not have a remote. Have cleaned dust filters regularly. Dust/lamp covers sitting correctly. Any suggestions are appreciated. Cheers
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
it is a little hard to test them. any help ,Pls contact me
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Posted on Mar 01, 2014
4 Suggested Answers
tvtechnician
  • 105 Answers
SOURCE: Both the LAMP/COVER and FAN/TEMP indicator lights come on, not blinking
with both lights solid. according to the manual all it says is (there is an electrical failure inside the unit, please take to an authorized servicer). if you are able to do this yourself you will need the schematics and a voltmeter to start testing your voltages. your lamp is fine so dont waste your money replacing that anymore. if you would like the service manual send me an email to fixya@markservicepro.com.
Posted on Oct 30, 2007
busgeek79
  • 36 Answers
SOURCE: Lamp cover light flashes even with new lamp
Look closely by the cover there is a small sensor there, could be a pice of dirt and door not completely closing get a cleanpaint brush or little brush and clean area..Good Luck
Posted on Jun 30, 2008
BlackOnyx
  • 102 Answers
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Posted on Feb 06, 2010
Sony vpl cs5 projector will not turn on now power what so ever... Fuse on main power board is fine and power is getting to the main board at the back of the projector (the board which runs the bulb) the...
Have you tried the following:
Connect the power cord and turn the projector to standby mode.
Press the following keys on the remote commander in the following order for
less than five seconds each: RESET, <,>, ENTER.
Feb 26, 2011 | Sony VPL CS5 Multimedia Projector
My projector will not power on. I've replaced the cables, the power source, and the bulb but still nothing. The red standby led on the control unit turns blue when power button is pressed but goes right...
The ballast unit has most likely failed. Replace the ballast unit, unless the lamp exploded and in which case, there may be glass fragments stopping a fan from turning.
Feb 03, 2011 | Optoma HD81 DLP Projector
How can i reset the lamp timer ???? Typ of beamer: Sony VPL-FX51 E-Mail:francois.humbert-prince@vtg.admin.ch
Connect with power cord and turn the projector to the standby mode.
Press the following keys on the control panel in the following order for less than in five seconds each: RESET, LEFT arrow key and RIGHT arrow key and then ENTER.(showing in the picture below)
(NOTE projector must be in standby mode and keys pressed less than five seconds)
now press power/standby key to ON the projector and check lamp hoursgood_help_1.png
Jan 31, 2011 | Sony VPL-FX51 Multimedia Projector
Digital projector not working
check if standby led on projector is glowig red, if yes pannel keys may be in off mode, try to power on with remote control.if standby led does not glow, check power cable and its connections and safety fuse inside projector.
Aug 14, 2010 | Sony VPL-ES1 Multimedia Projector
The device is an InFocus LP 290 with less than 100 hours on the bulb. I have used the projector several times over the course of two years without any problem, but never longer than 3 hours at a time. A...
there is an issue with the power supply edge connection with the main board. you'll need to have it sent to an infocus service center for repair. try av solutions in ny. they're pretty good. www.avsolutionsny.com
Nov 24, 2009 | InFocus LP290 1100 Lumen XGA LCD Projector...
LMP-H150 reset hours on sony cineza VPL-HS2
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS2
Jul 04, 2009 | Sony Cineza VPL HS2 Multimedia Projector
Sony cineza vpl hs51 projector won't project
Something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
The lamp may not have been changed - just the timer reset - How many hours has the lamp really done - 1000, 3000, 5000?
If you know that the hours are genuine, then was the quartz bulb contaminated with a touch of oil from skin contact?
This will substantially shorten lamp life, due to the quartz going milky and opaque.
The easiest way to check, is to pull the lamp and have a look at the bulb.
If need be replace the lamp and reset the lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS51
Dec 07, 2008 | Sony Projector Lamp for VPL-HS51
InFocus LP725 light goes out after 10 minutes
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
Feb 02, 2008 | InFocus LP725 and LP735 Replacement...
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
Infocus LP725 projector
May 25, 2007 | InFocus LP725 and LP735 Replacement...
Sony VPL-ES1 Multimedia Projector Logo
206 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
