Question about Dewalt DC011 AM/FM Radio
DEWALT DW911 i CAN'T GET IT OPEN TO CHECK THE FUSE. IT JUST STOPPED WORKING. CRHYNE
  • 1 more comment
  • Anonymous Mar 23, 2008
    NO POWER INTERNAL FUSE OK
  • Kiwi Fixer May 23, 2008
    Plug in the power lead. Do you hear a single click sound? Remove the eight screws holding on the back. Check fuses. Some time the fuse blows for no reason other times there is a fault. If fuses are OK the check there is power going out of the power transformer (Thin wires). It should be 15 Volts AC. Be carefull as there is Mains power with exposed tracks on the circuit board. Here in New Zealand our mains is 230Volts so it has a good 'bite' for the unwary. I had no Volts coming out of the transformer so I unsoldered the transformer leads. Make sure you unplug the mains first ! Checking with a tester revealed an open transformer winding on the Mains side (Big thick wires). Replaced the transformer from another DW911 and away she went. All go.
  • konka279 Apr 06, 2009
    I have the same problem exactly ! "open transformer" and I need a replacement but not sure what the output is susposed to be .
2 screws sunk in at the back left and right. no need to remove speaker screws.
Posted on Nov 19, 2007
I have a Dewalt radio (Dw911) that will only play off the battery, not the power cord. I have checked both fuses and found both to be good. It sounds as if this is a common issue but I have found no...
Mine had the same problem .Try swapping the fuses. Although the fuse looked good mine was bad. Easy fix I hope. Going to auto parts store for new ones.
Oct 09, 2010 | Dewalt Audio Players & Recorders
Dewalt radio dw911 will play on mains but nothing with battery only
If you pull of the back cover you will find two small fuses near power supply, one of these allows power from battery pack, check with voltmeter for open circuit, I take it that it is not just one battery it does this with.
Nov 27, 2007 | Audio Players & Recorders
My dewalt dw911 radio/charger works on either mains or battery but wont charge a battery and blows an internal fuse when both are used together
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Oct 24, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 cabinet seperation
go to www.dewaltservicenet.com
shearch by model DW911 loock the break bown
Feb 16, 2009 | Dewalt 18 Volt Compact Drill Kit
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
Dewalt radio dw911
Have you changed the AA Batteries, this is often the fault, when they are flat they lock the radio out. HHM Dewalt Service
Nov 27, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DW911 jobsite radio
Got mine open.
There was a fuse inside - Replaceable - fixed the problem.
There were no hidden screws, none under stickers or in the battery box like suggested by others, and the 2 magic release screws not so. There are several deep screws requiring a long philips, but the entire seam is glued (why?) so to open the radio I had to hit the body near the seam with a rubber hammer to crack the seam loose once all the screws were removed, comes right apart. Put it back together without glue, just the screws, it will be fine.
Sam. DesertSolutions.net
Sep 06, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
1,502 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
